Flash programing in 33fj series
embeddedpower1
Newbie level 3
I am trying to write code for flash programming in dspic 33fj64gs610. Writing is not happening in that. Can anybody share any sample codes for 33fj series
please read forum rules.
A forum is not meant that other write code for you or do an internet search for you.
A forum is meant that members help you to rectifiy the problems with your code.
Thus provide your code, your test setup, maybe schematic...
Tell us your expectation and what you see instead.
I presume you are referring to "self-programming" of dspic33 flash during program execution, used by a boot loader or e.g. EEPROM emulation. The algorithm is briefly explained in the device datasheet, for some applications, example code is also available from Microchip.
To get help with your specific problem, you should tell what you are trying to achieve and how you did it.
This is the code that i have written. Please give me suggestion if am wrong somewhere
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
while()
  unsigned int MyRowDataInRam[64]=
0,1,2,3,4,5,6,7,8,9.10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,
31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63};
 TBLPAG = __builtin_tblpage(&MyRowData2InFlash[0]);
 tbloffset = __builtin_tbloffset(&MyRowData2InFlash[0]);
 programErase();
 programWrite();
 programParametersRead();
DATA0= lowWord[0];
DATA1= lowWord[0];
DATA2= lowWord[2];
DATA3= lowWord[3];
DATA61= lowWord[61];
DATA62= lowWord[62];
DATA63= lowWord[63];
void programParametersRead() {
    TBLPAG =__builtin_tblpage(&MyRowData2InFlash[0]);
    for (i = 0; i <= 64; i++) {
        high_Word[i] = __builtin_tblrdh(tbloffset);
        lowWord[i] = __builtin_tblrdl(tbloffset);
        tbloffset += 1;
    return;
void programWrite()
    unsigned int tbloffset,i;
    NVMCON = 0x4001; // Row programming
         __builtin_tblwtl(tbloffset ,MyRowDataInRam[i] );
         tbloffset += 1;  }
       __builtin_disi(5);
      __builtin_write_NVM();
void programErase()
    NVMCON = 0x4042;
    __builtin_tblwtl(tbloffset , 0X0000);
    __builtin_tblwtl(tbloffset, 0xFFFF);// Dummy Write
    __builtin_disi(5);
  • samp.txt
Is this a typo?
Same is in your attached file.
