Results 1 to 5 of 5
    Points: 13,876, Level: 28
    nandhu015's Avatar
    Feb 2006
    India
    1,963
    13,876
    28
    Blog Entries
    18
    windows programming to create hex for microcontroller
    Hi
    I want to write a windows application that can create hex file for microcontrollers.
    I had seen single exe file that creates hex file for AVR micros, but there is no compilers called.
    Can any body give me an idea how to it is done.
    Any inputs, examples, links will be helpfull.
    I can write programmes for microcontrollers in C
    Nandhu
    Points: 77,678, Level: 67
    Apr 2014
    15,742
    77,678
    67
    Re: windows programming to create hex for microcontroller
    Create hex files... but what is the source?
    Points: 81,351, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,337
    81,351
    69
    If you want a hex file without a source file, I guess you are asking for a random number generator. Windows is good at generating random output!
    nandhu015's Avatar
    Feb 2006
    India
    1,963
    13,876
    28
    Blog Entries
    18
    Hex will be based on the windows application. For example the windows application is used to create designs / patterns of led matrix, which should be run from a microcontroller.
    Here is an example (not the same) i want accomplish
    https://www.facebook.com/eXtremeElec...8384989199697/
    Nandhu
    Full Member level 2
    Points: 1,051, Level: 7
    FlyingDutch's Avatar
    Dec 2017
    Bydgoszcz - Poland
    131
    1,051
    7
    Quote Originally Posted by nandhu015 View Post
    Nandhu
    you can write a program in C for microcontroller(skeleton), and Windows application - code generator (for example in C# using Visual Studio) which generates code also in C for microcontroller.
    You have to invent data structures which can control LED matrix behavior (for example structure in C). Then in windows application (maybe graphical) design these structures and generate C (microcontroller) code. Then paste the generated code to C (microcontroler) program and compile it in one of compilers for micro (this compliler can be for example free "Arduino IDE").
    You can save the generated code in *.h (C header files) and just include these files to your C program for microcontroler.
    This is the only way you can acomplish your assumptions, but it is a challenge (it is complex task).
