Results 1 to 9 of 9
    Advanced Member level 2
    Points: 2,890, Level: 12
    Feb 2016
    541
    2,890
    12
    Unitary property of scattering matrix
    From s-parameter lossless network definition , The sum of the incident powers at all ports is equal to the sum of the reflected powers at all ports.
    But how do we derive the above unitary property expression involving S22 and S21 ?
    Points: 15,391, Level: 29
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,361
    15,391
    29
    Re: Unitary property of scattering matrix
    Quote Originally Posted by promach View Post
    From S parameter’s definition.
    Points: 6,637, Level: 19
    Jun 2012
    Edmonton, Canada
    1,023
    6,637
    19
    Hi promach,
    Mathematically speaking, a unitary matrix is one which satisfies the property [S]^* = [S]^{-1}. Re-arranging, we see that [S]^* [S] = [I], where [I] is the identity matrix.
    Inserting the [S] matrix into this equation, we can then see that any column dotted with itself is equal to unity. Conversely, if any column is dotted with any other column, the product is equal to 0.
    So if we take your 2x2 scattering matrix and look at some examples, we would find that |S12|^2 + |S22|^2 = 1. If the network is reciprocal, then S12 = S21. We would also have that |S11|^2 + |S21|^2 = 1 and (S11*)(S12) + (S21*)(S22) = 0.
    Oct 2006
    Real Homeless
    2,361
    15,391
    29
    Quote Originally Posted by PlanarMetamaterials View Post
    Reciprocity is not required.
    From nature of Unitary Matrix, [S]^* [S] = [S] [S]^* = [I]
    So |S21|^2 + |S22|^2 = 1 is satisfied without reciprocity.
    Member level 4
    Points: 578, Level: 5
    Aug 2018
    79
    578
    This could be explained by law of conservation of energy. The injected power must be equal to the reflected power + the transmitted power for a lossless network.
    Feb 2016
    541
    2,890
    12
    Quote Originally Posted by pancho_hideboo View Post
    Wait, I do not understand why [S]^* [S] = [S] [S]^* = [I]
  7. #7
    Oct 2006
    Real Homeless
    2,361
    15,391
    29
    It is matrix nature of kindergarten level.
    For [B][A]=[I], [B] has to be [A]^{-1}.
    So [A][B]=[I] is satisfied.
    This has no relation to S-parameter at all.
    That’s all.
  8. #8
    Feb 2016
    541
    2,890
    12
    @pancho_hideboo
    For ideal lossless case:
    transmitted power + reflected power = source power
    So, divide the whole expression just above by source power, we have the following:
  9. #9
    Oct 2006
    Real Homeless
    2,361
    15,391
    29
    You can not understand things correctly.
    Wrong.
    We can not get this directly from "transmitted power + reflected power = source power".
    We have followings from "transmitted power + reflected power = source power".
    However from matrix nature of kindergarten level, |S21|=|S12| is satisfied.
    So |S21|^2 + |S22|^2 = 1 is satisfied.
    This does not require reciprocity at all.
    Learn basic things surely.
    Attached is an excerption from kindergarten level book.
    Here "~" means conjugate complex and transpose.
