Results 1 to 6 of 6
    Newbie level 3
    Points: 57, Level: 1
    May 2019
    57
    How to generate Frame Clock(FR) of the ADC?
    Hello everyone,
    I'm using a FMC board card with ADC - LTC2174. After powered on,I can detect Data output clock (DCO) signal of the ADC with Oscilloscope. However I can't detect Frame Clock (FR) signal.
    1. I think that FR signal will be automatic generated after ADC powered on (just like DCO signal). Is that actually true?
    2. I don't connect analog inputs of ADC. Must analog inputs be connected in order to generate FR signal?
    Points: 260,224, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    Re: How to generate Frame Clock(FR) of the ADC?
    1 yes 2 no. There's no way to disable FRC separately.
    Newbie level 3
    May 2019
    57
    Thanks FvM. So is this means that ADC may be destroyed?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    That's a possible explanation. Or shorted FRC output. Not sure if an ENC input signal outside specified frequency and level range may cause a similar effect too.
    Points: 77,800, Level: 68
    Apr 2014
    15,764
    77,800
    68
    I used the LTC2170, which has an identical interface.
    Defective IC is possible, but I think it´s not very likely.
    You know that they are LVDS signals and thus only have a small differential voltage level. Relatively hard to measure with a scope, but for sure possible.
    Is your scope able to trigger at the differential voltage between the FR-pair?
    Newbie level 3
    May 2019
    57
    I tested the line on FMC. It seems that the problem lies in the connection of the line.
    Hi Klaus,
    I think the scope that I used can capture differential FR signal. Becaues it has detected DCO signal which is also LVDS signal and has the same voltage level as FR. Anyway, I found that there is a problem on the line connection of FMC board card.
    Thanks for your reply.
