Results 1 to 4 of 4
    Junior Member level 2
    Points: 641, Level: 5
    Dec 2016
    23
    641
    Calculating SNR from for an ADC
    i am trying to calculate the SNR for the Ideal ADC model in cadence ahdllib , i know that it should be equal to or around 6.02N+1.76
    i have implemeted a code to calculate the FFT of the output of ADC using matlab and i will attach the code
    my problem is that i dont know how to calculate the SNR from the FFT of the output signal
    Afs = 5;
    fs = 1e6;
    N = 2048;
    cycles = 5;
    fx = fs*cycles/N;
    t = linspace(0, (N-1)/fs, N);
    %signal frequency
    y = table2array(bitsinfullscale);
    y = y';
    s = (abs(fft(y)/N/Afs*2));
    % drop redundant half
    s = s(1:N/2);
    f = (0:length(s)-1) / N*fs;
    figure
    plot(t,y)
    hold on;
    figure
    plot(f,s)
    Points: 83,926, Level: 70
    Apr 2014
    17,064
    83,926
    70
    Re: Calculating SNR from for an ADC
    N = 2048;
    Mind that both "N" represent different things.
    SNR = Signal to Noise Ratio = Signal / Noise.
    SNR usually is given in "dB" and signal and noise are given in voltage_RMS.
    Thus in most cases: SNR(dB) = 20 x log(Signal_RMS / Noise_RMS)
    Signal_RMS
    .. is usually a single sinusoidal signal. Thus signal(RMS) in LSB = 2^ADC_bit_resolution / (2 x sqrt(2))
    Example: for a 16 bit ADC: 23170 LSB_RMS
    Noise_RMS
    ...is the sum of all frequencies voltage_RMS. (except DC)
    noise_RMS = sqrt( n1_RMS^2 + n2_RMS^2 +n3_RMS^2 ....)
    Dec 2016
    23
    641
    thanks KlausST but i want to calculate it from the data collected from the FFT i will attach the signal
    it is a sine wave output for 4 bit Ideal ADC
    Afs = 5;
    fs = 1e6;
    N = 2048;
    cycles = 5;
    fx = fs*cycles/N;
    %signal frequency
    y = y';
    s = 20*log10 (abs(fft(y)/N/Afs*2));
    s = s(1:N/2);
    figure
    plot(t,y)
    hold on;
    figure
    plot(f,s)
    bx = N*fx/fs + 1;
    As = 20*log10 (s(bx));
    %set signal bin to 0
    s(bx) = 0;
    An = 10*log10 (sum(s.^2));
    SNR = As - An
    Apr 2014
    17,064
    83,926
    70
    then just take bin5 as your "signal", and all the rest (without DC) as noise.
    But your "sine" is distorted... and it seems it just has 4 bits of resolution, thus you get a lot of overtones.
    These overtones play a big role in caclulation.. and thus you don´t get "noise only" --> the result is more "THD+N" instead of "SNR".
    --> either use a THD free input signal, or don´t use an input signal at all.
