Results 1 to 5 of 5
    Advanced Member level 3
    Points: 4,968, Level: 16
    Jan 2012
    Italy
    863
    4,968
    16
    Common centroid matching array
    Dear friends,
    I have question about the common centroed matched array. I have this array for example to match two transistors A and B
    ABBA
    BAAB
    ABBA
    BAAB
    or I can make it
    ABBA
    BAAB
    for sure the first array is supposed to be the best but during work I see it is consuming a lot of wiring which I think it will add considerable parasatics.
    The second array is working fair but it has a problem with big transistors in which dividing them by 4 is not enough. Therefore I have two options in which I want to take your opinion on
    the first is extending the array horizontally like this way
    ABBA ABBA
    BAAB BAAB
    or I keep using the
    ABBA
    BAAB but using two gate per unit transistor in the array
    Which one you think it match better ?
    Thank you in advance
    Points: 1,080, Level: 7
    Oct 2014
    51
    1,080
    7
    Re: Common centroid matching array
    In my opinion, the second placement is good enough. It's simple for wiring and still get matching for A, B transitor.
    There will be trade off when we choose too complex placement. Like wiring complexibility, parasitic resitor and capacitor...
    Jan 2012
    Italy
    863
    4,968
    16
    Thank you quyla for your answer
    Jan 2012
    Italy
    863
    4,968
    16
    Common centroid array arrangement
    Dear friends,
    what is the difference between the two below arrays in term of better matching
    ABBA
    BAAB
    and
    ABAB
    BABA
    Thank you
    Oct 2014
    51
    1,080
    7
    The second is seems better for matching when it has better common centroid.
    One more thing is the number finger of A and B in the second configuration should be even for abut.
