Results 1 to 11 of 11
    Member level 4
    Points: 1,715, Level: 9
    Dec 2011
    79
    1,715
    9
    rem and mod operators
    Hi
    There is a question about synthesizing mod/rem operators.
    X mod N where N is positive:
    This can be synthesized by taking the least log2(N) bits of X.
    X can be positive of negative (2's complement).
    How about negative N numbers?
    For example, 1 mod -4 = -3
    How this is synthesized?
    The same question exists for rem.
    -1 rem 4 = -1
    -1 rem -4 = -1
    Points: 256,061, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,650
    256,061
    100
    Re: rem and mod operators
    Presume you are asking about VHDL. You can review ieee.numeric_std library how mod and rem are evaluated. Both are finally referring to unsigned division DIVMOD(). With power of two denominator, it reduces to shift and mask operation and can be implemented without actual division operation.
    Non power-of-two right hand operand may infer a parallel divider, depending on the tool capabilities.
    Advanced Member level 1
    Points: 2,387, Level: 11
    Aug 2016
    414
    2,387
    11
    Although it is not clear what you are asking for but I'll just give it a shot.
    A rem B = C:
    in this case C is the remainder after dividing the absolute value of A by the absolute value of B.
    C has the same sign as A irrespective of the sign of B.
    A mod B = C:
    In this case, C is the remainder after dividing the absolute value of A by the absolute value of B.
    C has the same sign as B irrespective of the sign of A.
    I hope that's what you asked for. If not, you may have to rephrase your question for better understanding.
    --Akanimo.
    Member level 4
    Dec 2011
    79
    1,715
    9
    Lets say in VHDL we have written while assuming that A and B are bit_vector(7 downto 0)
    A := B mod 4;
    How that is synthesized? Simply mask B with a pattern which is (B AND 000000011). So it is an AND gate.
    Now, I want to know how to synthesize (1 mod -4)? The right hand operand is power of 2.
    If we use an AND gate with absolute value of the negative right operand and then find the 2's complement of the result, then the result is invalid. For example, first we have (1 mod 4) which is (00000001 AND 00000011) which is (00000001) and then complement it to get (11111110) which is (-1) and not -3.
    Can you explain that?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,650
    256,061
    100
    Near. You calculate 1 MOD -4 = (1 MOD 4) - 4 = -3.
    Aug 2016
    414
    2,387
    11
    Why do you think that 1 mod 4 is synthesised using an AND gate? Try 6 MOD 3 with an AND gate and you won't get 0.
    This is the analytical implication
    MOD:
    A = B*N + (A mod B) where N is a integer and A mod B is as described in pots #3.
    REM:
    A = (A/B)*B + (A rem B); where A rem B is as described in post #3.
    If you are always going to perform (1 mod -4) then leave the operation and take the answer which is -3. Operators are for arbitrary values so all test cases must yield their correct answer with a certain method before you adopt the method.
    The best bet would be to use a for loop.
    --Akanimo.
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,650
    256,061
    100
    As far as I understand, the OP wants to implement MOD operation for power of two denominator. That's of course possible without a divider.
  8. #8
    Aug 2016
    414
    2,387
    11
    Quote Originally Posted by mahmood.n View Post
    A := B mod 4;
    (1 mod -4) is -1 -------not -3
    (1 mod 4) is 0 remainder 1
    giving that result of 1 the sign of -4 results in -1
    Your method if masking with 00000011 is correct because (1 mod 4) = (00000001 AND 00000011) = (00000001).
    If we take the MSB as the sign bit, then Taking the 2's compement of (00000001) gives (11111110 + 00000001) = (10000001) which is -1.
    --Akanimo.
  9. #9
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,650
    256,061
    100
    My VHDL tool says it's -3, no reason to doubt about. Please review numeric_std.vhd how it's calculated.
    Code VHDL - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    if XL(XL'LEFT)='1' then
          XNUM := UNSIGNED(-XL);
        else
          XNUM := UNSIGNED(XL);
        end if;
        if XR(XR'LEFT)='1' then
          XDENOM := UNSIGNED(-XR);
          RNEG := TRUE;
        else
          XDENOM := UNSIGNED(XR);
        end if;
        DIVMOD(XNUM, XDENOM, FQUOT, FREMAIN);
        if RNEG and L(L'LEFT)='1' then
          FREMAIN := "0"-FREMAIN;
        elsif RNEG and FREMAIN/="0" then
          FREMAIN := FREMAIN-XDENOM;
        elsif L(L'LEFT)='1' and FREMAIN/="0" then
          FREMAIN := XDENOM-FREMAIN;
        end if;
        return SIGNED(FREMAIN);
    Result -3 also fulfills the identity given in post #6:
    A = B*N + (A MOD B)
    1 = -4*-1 + -3
  10. #10
    Aug 2016
    414
    2,387
    11
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
        else
        end if;
          RNEG := TRUE;
        else
        end if;
        end if;
    A = B*N + (A MOD B)
    1 = -4*-1 + -3
    Yes, you're right. That was me and my blunder. Apologies.
    I noticed something that I'd like you to confirm:
    If A and B bear the same sign, then (A mod B) = (A rem B).
    --Akanimo.
  11. #11
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,650
    256,061
    100
    Yes, that's true.
