Results 1 to 16 of 16
    Member level 4
    Points: 1,110, Level: 7
    Jun 2015
    77
    1,110
    7
    Vivado Taking A Long Time To Run Synthesis & Implementation
    I am new to Vivado , but it seems like Vivado 17.4 takes longer than it should to run through Synthesis and Implementation, i'm working on a design of sha-512 algorithm( hash function using in security) ,utilization is attached.
    it takes around 3 hours to complete implementation.
    Is my computer is an effective factor or it is normal in vivado? and how can i speed this up?
    Points: 8,111, Level: 21
    Apr 2016
    1,707
    8,111
    21
    Re: Vivado Taking A Long Time To Run Synthesis & Implementation
    Quote Originally Posted by MSAKARIM View Post
    runtime is proportional no only to design size. maybe the target frequency is too high and the tool spends a lot of time optimizing. maybe the IO/floorplan is bad and the tool tries to overcome that.
    Really, I am not Sam.
    Points: 256,061, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,650
    256,061
    100
    Sounds like a poorly designed (e.g. pure combinational) sha implementation which hardly meets timing.
    Points: 30,595, Level: 42
    ads-ee's Avatar
    Sep 2013
    USA
    7,038
    30,595
    42
    Evidence for it lacking pipelining...
    LUT utilization of 17%
    FF utilization of 1%
    along with IO utilization of 70% means the design is spread all over the die but has virtually no registers to pipeline across the die.
    I recall other threads on aspects of this design and from what I remember of the code snippets, I didn't think this design would run better than a few MHz.
    Full Member level 5
    Points: 2,171, Level: 10
    May 2014
    253
    2,171
    10
    You can get timestamps for when the various parts of par complete.
    This way you can get a feel for how long design init, opt_design, place_design and route design take.
    If you "pipelined" then the tool has an easier time during placement.
    Member level 4
    Jun 2015
    77
    1,110
    7
    SHA algorithm has 80 rounds (iterations), may this be the reason?
    is Loop Pipelining or Loop Unrolling like that https://www.xilinx.com/support/docum...unrolling.html enhancing the design performance?
    Quote Originally Posted by ads-ee View Post
    Yes, i have posted threats about this before, but honestly i changed more things to enhance it and still takes long time during implementation.
  7. #7
    ads-ee's Avatar
    Sep 2013
    USA
    7,038
    30,595
    42
    If you are doing this in HLS then you need the pragma for pipelining according to that page.
  8. #8
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,650
    256,061
    100
    The link is about pipelining with HLS compiler, not applicable to generic HDL code.
    As far as I understand, you are coding in generic VHDL. You need to implement pipelining explicitly using a clock and pipeline registers.
  9. #9
    Member level 4
    Jun 2015
    77
    1,110
    7
    If i have this code partition:
    w(15)<=Message_block(63 downto 0);
    w(14)<=Message_block(127 downto 64);
    w(13) <=Message_block(191 downto 128);
    w(12)<=Message_block(255 downto 192);
    w(11) <=Message_block(319 downto 256);
    w(10) <=Message_block(383 downto 320);
    w(9) <=Message_block(447 downto 384);
    w(8) <=Message_block(511 downto 448);
    w(7) <=Message_block(575 downto 512);
    w(6) <=Message_block(639 downto 576);
    w(5) <=Message_block(703 downto 640);
    w(4) <=Message_block(767 downto 704);
    w(3)<=Message_block(831 downto 768);
    w(2)<=Message_block(895 downto 832);
    w(1)<=Message_block(959 downto 896);
    w(0)<=Message_block(1023 downto 960);
    wordGen : for t in 16 to (79) generate
     WOW : WordT port map(w((t-2)), w((t-7)) , w((t-15)) , w((t-16)),w(t));
    end generate ;
    How can i make it pipelined?
    what about this try ( adding this part to the previous code):
    REGIS: for i in 0 to 79  generate
    reg: Reg64 port map (clk,rst,w(i),wo(i));
    end generate;
    where REG64 code is:
    entity Reg64 is
     Port (clk,rst:in std_logic;
           D: in std_logic_vector(63 downto 0);
           RegW: out std_logic_vector(63 downto 0) );
    end Reg64;
    architecture Behavioral of Reg64 is
    begin
    process(clk,rst)
    begin
    if (rst ='0' ) then RegW <= (others=> '0');
    elsif (clk'event and clk = '1') then
    RegW <= D;
    end if;
    end process;
    end Behavioral;
  10. #10
    Apr 2016
    1,707
    8,111
    21
    I can't understand what you are doing (coding a register bank?!), but it doesn't look like pipelining. when we say to pipeline we mean to split a long combinational logic into two or more stages. the first code snippet has no combinational logic, just some mapping. I doubt that is the problem.
  11. #11
    Member level 4
    Jun 2015
    77
    1,110
    7
    Re: Vivado Taking A Long Time To Run Synthesis &amp; Implementation
    Quote Originally Posted by ThisIsNotSam View Post
    " when we say to pipeline we mean to split a long combinational logic into two or more stages "
    >> i did this and still take more time.
    This a part of my original code, Plz i need some notes (just notes) to make it pipline:
    library IEEE;
    use IEEE.STD_LOGIC_1164.all;
    use IEEE.NUMERIC_STD.All;
    use IEEE.STD_LOGIC_UNSIGNED.ALL;
    entity Round_sha is
    port( clk,rst,init: in STD_LOGIC;
          IV: in std_logic_vector(511 downto 0);
          Message_block: in std_logic_vector(1023 downto 0);
         Hashed_512: out std_logic_vector(511 downto 0));
    end Round_sha;
    architecture rtl of Round_sha is
    component K_rom IS
    PORT ( addr: IN INTEGER RANGE 0 TO 79;
    data: OUT STD_LOGIC_VECTOR (63 DOWNTO 0));
    END component;
    component WordT is
    port (w2,w7,w15,w16: in std_logic_vector (63 downto 0);
          wnext: out std_logic_vector (63 downto 0));
    end component;
    Component Func_round is
    port(a,b,c,e,f,g: in std_logic_vector(63 downto 0);
    f0,f1,f2,f3: out std_logic_vector( 63 downto 0));
    end component;
    type word is array (-1 to 79 ) of std_logic_vector(63 downto 0);
    signal a,b,c,d,e,f,g,h:word;
    type word2 is array (0 to 79 ) of std_logic_vector(63 downto 0);
    signal w,f0,f1,f2,f3,k: word2;
    begin
    --assigning block to words
    --words from t=0:15
    a(-1) <= IV(511 downto 448);        -- <= X"6a09e667f3bcc908";
    b(-1) <= IV(447 downto 384);        -- <= X"bb67ae8584caa73b";
    c(-1) <= IV(383 downto 320);        -- <= X"3c6ef372fe94f82b";
    d(-1) <= IV(319 downto 256);        -- <= X"a54ff53a5f1d36f1";
    e(-1) <= IV(255 downto 192);        -- <= X"510e527fade682d1";
    f(-1) <= IV(191 downto 128);        -- <= X"9b05688c2b3e6c1f";
    g(-1) <= IV(127 downto 64) ;       -- <= X"1f83d9abfb41bd6b";
    h(-1) <= IV(63 downto 0);        -- <= X"5be0cd19137e2179";
    --words from t=16:79
     WOW: WordT port map(w((t-2)) , w((t-7)) , w((t-15)) , w((t-16)),w(t));
    end generate ; -- wordGen
    Funcc: for i in 0 to 79  generate
    Func: Func_round port map(a(i-1),b(i-1),c(i-1),e(i-1),f(i),g(i),f0(i),f1(i),f2(i),f3(i));
    KROM: K_rom     port map (i,k(i));
            h(i)          <=  g(i-1);
            g(i)          <=  f(i-1);
            f(i)          <=  e(i-1);
    --	e          <=  d +          T1        ;
    --      e          <=  d + h + f3 + f0 + k + w;
            e (i)         <= std_logic_vector(unsigned(d(i-1)) + Unsigned(h(i-1)) + unsigned(f3(i)) + unsigned(f0(i)) + unsigned(k(i)) + unsigned(w(i)));
            d (i)         <=  c(i-1);
            c (i)         <=  b(i-1);
            b (i)         <=  a(i-1);
    --	a          <=             T1           +    T2  ;
    --      a          <=      h + f3 + f0 + k + w + f2 + f1;
            a(i)          <= std_logic_vector(unsigned(h(i-1)) +unsigned(f3(i)) + unsigned(f0(i)) +unsigned(k(i)) + unsigned(w(i))  + unsigned(f2(i)) + unsigned(f1(i)));
    end generate;
     process (clk,rst)
    variable   H0 , H1 , H2 , H3 , H4 , H5 , H6 ,H7     :     Std_logic_vector ( 63 downto 0);
      begin
          if (rst = '1') then
            H0         := X"6a09e667f3bcc908";
            H1         := X"bb67ae8584caa73b";
            H2         := X"3c6ef372fe94f82b";
            H3         := X"a54ff53a5f1d36f1";
            H4         := X"510e527fade682d1";
            H5         := X"9b05688c2b3e6c1f";
            H6         := X"1f83d9abfb41bd6b";
            H7         := X"5be0cd19137e2179";
          elsif  (init ='1') then
            if ((clk = '1') and clk'event) then
            H0         := std_logic_vector( unsigned(a(79)) + unsigned(a(-1)));
            H1         := std_logic_vector( unsigned(b(79)) + unsigned(b(-1)));
            H2         := std_logic_vector( unsigned(c(79)) + unsigned(c(-1)));
            H3         := std_logic_vector( unsigned(d(79)) + unsigned(d(-1)));
            H4         := std_logic_vector( unsigned(e(79)) + unsigned(e(-1)));
            H5         := std_logic_vector( unsigned(f(79)) + unsigned(f(-1)));
            H6         := std_logic_vector( unsigned(g(79)) + unsigned(g(-1)));
            H7         := std_logic_vector( unsigned(h(79)) + unsigned(h(-1)));
    --      h0         <=      a + h0;
    --      h1         <=      b + h1;
    --      h2         <=      c + h2;
    --      h3         <=      d + h3;
    --      h4         <=      e + h4;
    --      h5         <=      f + h5;
    --      h6         <=      g + h6;
    --      h7         <=      h + h7;
        end if;
    end if;
    Hashed_512<= H0&H1&H2&H3&H4&H5&H6&H7;
      end process;
    end rtl;
  12. #12
    Points: 37,484, Level: 47
    Jun 2010
    6,810
    37,484
    47
    why is init outside the clock condition?> you're forcing the clock into logic, which is probably causing massive timing failures. Either put the init check inside the clock or remove it altogether.
    You also have massive logic chains as I dont see any pipelining between the components generated in the large generate loops! You need pipelining at ALL stages, not just the output stage. You design has basically zero pipelining.
  13. #13
    Advanced Member level 3
    Points: 6,045, Level: 18
    Feb 2015
    991
    6,045
    18
    Any pipeline latency appears in the longest feedback path due to the output of the 80-rounds being the init for the next chunk. Maybe pipelining would help for the immediate problem of synthesis times, but the resulting design isn't that good anyways.
    The 6kW power estimate is interesting.
  14. #14
    Member level 4
    Jun 2015
    77
    1,110
    7
    Quote Originally Posted by TrickyDicky View Post
    please give some example or notes how can i make pipline in that loops
    Quote Originally Posted by vGoodtimes View Post
    How can i reduce this excessive power (too high) ?
  15. #15
    Apr 2016
    1,707
    8,111
    21
    I think you need help from a professor/class or a textbook. You keep asking the same question over and over when the answer was already given.
  16. #16
    Feb 2015
    991
    6,045
    18
    I think he's asking a slightly different question that what's been answered. His problem is more similar to "how do you pipeline an IIR filter". The SHA512 computation has rounds where the output of each round becomes the input to the next. This is a tight feedback loop, similar to the IIR filter. The output after these rounds then becomes part of the input for the next chunk -- another feedback path like the IIR filter.
