Results 1 to 11 of 11
    Points: 224, Level: 2
    Feb 2019
    38
    224
    any solution to amplify the MCP4261 current
    Used a MCP4261 to generate a signal to control a analog joystick, seems its max current is too small, anyway can amplification it's signal?
    Thanks.
    Points: 24,282, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,656
    24,282
    37
    Re: any solution to amplify the MCP4261 current
    What? You want to amplify a POTENTIOMETER?
    Are you saying you want to put more current through the device than it can handle? Why? Maybe if you told us a little more about what you’re actually trying to do.
    Points: 81,430, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,348
    81,430
    69
    Even stranger, they want it to control an analog joystick. Attaching a joystick to an SMD IC sounds like a recipe for it being ripped off the board to me.
    Feb 2019
    38
    224
    Quote Originally Posted by barry View Post
    Ya,
    is it possible to use a Transistor kind?
    Should say to replace the control of an analog joystick(AJ).
    Points: 77,803, Level: 68
    Apr 2014
    15,767
    77,803
    68
    impossible to answer without the requested informations.
    --> Show a schematic and give values and give your requirements.
    Feb 2019
    38
    224
    Thanks, the info. attached.
    The funny thing is with these circuit and code, output at pot0 = 2.5 V, the output at pot1 vary: 0 - 5 V, whats wrong? tested few pieces all same.
      This code used to control the digital potentiometer
      MCP41100 connected to  arduino Board
      CS >>> D10
      SCLK >> D13
      DI  >>> D11
      PA0 TO VCC
      PBO TO GND
      SHDN >> 9
      PW0 TO led with resistor 100ohm .
    #include <SPI.h>
    byte addressPot0 =     0b00010001;      //To define potentiometer use last two BITS 01= POT 0
    byte addressPot1 =     0b00010010;      //To define potentiometer use last two BITS 10= POT 1
    byte addressPot0and1 = 0b00010011;  //To define potentiometer use last two BITS 10= POT 0 and 1
    byte CS= 10;    //Chip control goes to pin 10
    byte SHDN = 9;  //Chip SHUTDOWN - PIN 9
    byte RS = 8;    //Chip RESET - PIN 8
    void setup()
      pinMode (CS, OUTPUT); //CS - When High, sets chip to read the data.
      pinMode (SHDN, OUTPUT); //CS - When High, sets chip to read the data.
      pinMode (RS, OUTPUT); //CS - When High, sets chip to read the data.
      digitalWrite(SHDN, HIGH); //Power ON (HIGH)
      digitalWrite(RS, HIGH); //Power NO RESET (LOW)
      SPI.begin();
    void loop()
      PotHighAndLow_mt(addressPot0);      //Change POT values on Pot0
      PotHighAndLow_mt(addressPot1);     //Change POT values on Pot1
      PotHighAndLow_mt(addressPot0and1); //Change POT values on both
      digitalPotWrite(245,  addressPot1);
      digitalWrite(SHDN, LOW); //Power OFF (LOW)
      delay(5000); //delay for 5 seconds to test current consumption of potentiometer
      digitalWrite(RS, LOW); //Power NO RESET (LOW)
      delay(100); //delay 100 mls
      digitalWrite(RS, HIGH); //Power RESET (HIGH)
      delay(10000); //delay 10 sec
    void PotHighAndLow_mt(byte address)
      /* We have limit from 130 - 255 just for LED test, but for other projects it can be 0-255 */
          for (int i = 130; i <= 255; i++)
          digitalPotWrite(i,address);
          delay(10);
       // delay(500);
        for (int i = 255; i >= 130; i--)
          delay(10);
    int digitalPotWrite(byte value, byte address)
      digitalWrite(CS, LOW); //Set Chip Active
      SPI.transfer(address);
      SPI.transfer(value);
      digitalWrite(CS, HIGH); //Set Chip Inactive
  7. #7
    Apr 2014
    15,767
    77,803
    68
    review your given informations:
    * We see no joystick
    * we see that there is nothing connected to the potīs wiper
    * we canīt know what current you talk about
    .. and so on...
    really a riddle...
  8. #8
    Feb 2019
    38
    224
    .. and so on...
    really a riddle...
    1. no joystick for now, just multi meter test the V at p6 and p9, and the output is the result.
    2. currently ' testing the MCP461, use it if its good.
  9. #9
    Apr 2014
    15,767
    77,803
    68
    Please review all your informations and give unambiguous informations.
    It takes too much time for us to find out what you want to tell:
    Some examples:
    MCP41100 connected to arduino Board --> There is no MCP41100
    CS >>> D10 --> There is no D10
    SCLK >> D13 --> There is no D13
    DI >>> D11 --> There is no DI and no D11
    PA0 TO VCC --> There is no PA0
    PBO TO GND --> There is no PBO
    SHDN >> 9
    PW0 TO led with resistor 100ohm . --> There is no PW0, no LED, and no information about the second connection of the LED
    1. no joystick for now, just multi meter test the V at p6 and p9, and the output is the result. --> There is no p6, no p9. Measuring the voltage ... but initially you talk about current. and what do you mean by "result"?
    Clarify all your informations of all your posts, because these are just a couple of doubtful informations.
  10. #10
    Feb 2019
    38
    224
    Some examples:
    SHDN >> 9
    Well, the diagram and code from: https://www.instructables.com/id/Dig...-with-Arduino/
    the red you point out are inside /* */ .
    the p6 and p9 mean pot wiper;
    I was trying to do some thing on joystick and the mcp4261 do have a larger current, but I need to test the MCP4261 is good or not firstly, now the mcp4261 can pass the test.
  11. #11
    barry's Avatar
    Mar 2005
    California, USA
    4,656
    24,282
    37
    Nope. I quit.
