Results 1 to 6 of 6
    Advanced Member level 3
    Points: 5,074, Level: 16
    Jan 2012
    Italy
    878
    5,074
    16
    Plotting waveform in Mathlab from Cadence
    Dear friends,
    I would like to ask your help on how can I plot my waveform result from Cadence Vertuso in Matlab. The reason is that the cadence waveform images is not good to attach in study report.
    Thank you very much
    Points: 16,320, Level: 30
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,496
    16,320
    30
    Re: Plotting waveform in Mathlab from Cadence
    It depends on simulator and it’s data format you use.
    Jan 2012
    Italy
    878
    5,074
    16
    I am using Virtuoso version IC6.1.5-64
    Oct 2006
    Real Homeless
    2,496
    16,320
    30
    Quote Originally Posted by Junus2012 View Post
    This is a design framework.
    It has no relation.
    Understand things correctly.
    If your data format is .tr0, use HSPICE Toolbox.
    If your data format is psf or sst2, use Spectre Toolbox.
    However I don’t know whether Spectre Toolbox supports psfxl format or not.
    See https://www.edaboard.com/showthread.php?375833
    Full Member level 3
    Points: 995, Level: 7
    Jan 2018
    157
    995
    7
    Dear friends,
    I usually export data into .csv file from the plot and import it into excel. I think you can do the same with matlab
    Full Member level 1
    Points: 1,354, Level: 8
    Mar 2015
    USA
    111
    1,354
    8
    Like circuitking said, csv formats work well. if you plot the data in virtuoso, or select it in the ADEXL window, you can export as csv. Importing the data into matlab will create a vector that you can then use simple plot commands to create your plot.
