Results 1 to 14 of 14
    Points: 40, Level: 1
    May 2019
    40
    H-bridge current spike
    I'm simulating the following a class D amplifier as shown in the image. The PWM driving scheme is bipolar (25 kHz), the load is 20mH+1.9R, the driving resistors and the dead time (250ns) correspond to those of the gate driver I choose.
    The actual transistor I'll be using is the CSD18540Q5B, but as there is no open spice model of it, I'm simulating with the IPB090N06N3 which seems to be similar.
    The problem I find is that simulation shows a current spike on the lower transistor each time it turn on. Do you know where might it come from?
    Thanks,
    Federico
    Full Member level 3
    Points: 832, Level: 6
    Jan 2019
    169
    832
    Re: H-bridge current spike
    Please show a few more simulations:
    the gate drives for all 4 FETs (i.e. GS voltage)
    the drain currents of all 4 FETs
    •   AltAdvertisment
    May 2019
    40
    thanks for the quick response.
    Here are some images of the simulations.
    Points: 255,029, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,438
    255,029
    100
    Why not post the zipped *.asc file so everyone can check the results on his own?
    May 2019
    40
    As suggested, I attach the .asc file.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,438
    255,029
    100
    At first sight, it's just Cds charging current. Increase the Rgchx gate resistors if you worry about the peak current.
    •   AltAdvertisment
  7. #7
    Points: 34,845, Level: 45
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Sep 2007
    Richmond Hill, ON, Canada
    6,706
    34,845
    45
    Blog Entries
    7
    I'd consider a soft start
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
  8. #8
    May 2019
    40
    Thanks, that does reduce the spikes, but it also reduces the system efficiency. Moreover, I'm trying to increase the switching frequency to 100 kHz in order to reduce the filter, but I can't get it to more than 83%. What do you you suggest I do?
  9. #9
    Points: 8,269, Level: 21
    Aug 2015
    1,311
    8,269
    21
    you might consider putting in a resistive load on the sim ...
    the sim might be giving the reverse recovery in the other fet - hence the current spike - ignore for now ...
    •   AltAdvertisment
  10. #10
    May 2019
    40
    Understood. However, now I have the following questions:
    1) Why do you say I may ignore reverse current for now? Is it overestimated by the simulation?
    2) How can you say the current due to Cds is 4.5 A?
    3) How could I improve efficiency?
    Many thanks
  11. #11
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,438
    255,029
    100
    You are right, it's mostly reverse recovery current. Peak current of open half bridge (Cds related) is only 4.5 A.
    As said, operating the half bridge without load connection gives the Cds related switching current.
    Don't know if the model is accurate, but reverse recovery is probably not overestimated. Easy peasy is assuming that the real application involves a real load and less reactive current. If that's not the case, you might look for transistors with faster body diode.
  12. #12
    Aug 2015
    1,311
    8,269
    21
    not Cds, reverse recovery of internal diode - if you dissect the fet model you may see it there ... - in real world it will likely be less for the Rgate used
  13. #13
    May 2019
    40
    I understand that is unavoidable. However, my interest is in efficiency, as the system will be battery powered. How can I improve it?
  14. #14
    Aug 2015
    1,311
    8,269
    21
    you seem not quite to understand the full import of the word - unavoidable. Your sim and the real world will be different, choose mosfets with fast anti-parallel diodes ( they are an intrinsic part of the fet )
