Results 1 to 7 of 7
    Full Member level 6
    Points: 4,159, Level: 15
    Jul 2006
    USA
    387
    4,159
    15
    A zero at folded cascode apmlifier
    Why there is a zero by counting the gain from the input to node2. Why the gain at high frequency is gm1/gm2? Thanks.
    page 10.
    http://ece.tamu.edu/~spalermo/ecen47...ascode_ota.pdf
    •   AltAdvertisment
    Advanced Member level 3
    Points: 8,910, Level: 22
    Nov 2001
    US
    750
    8,910
    22
    Re: A zero at folded cascode apmlifier
    Because looking into the source of at low enough frequencies you see big resistance and gain is defined by ro1||ro5. When CL reduces the impedance at the output, then looking into n2 you start seeing 1/gm2 and you get the behavior shown on the plots.
    Nov 2001
    US
    750
    8,910
    22
    Quote Originally Posted by sutapanaki View Post
    The above should read " Because looking into the source of M2 at low enough frequencies...."
    •   AltAdvertisment
    Full Member level 6
    Jul 2006
    USA
    387
    4,159
    15
    That's really helpful. Could you please explanate the zero? Why there is a zero and why the zero location is that? Thank you.
    Nov 2001
    US
    750
    8,910
    22
    Here is a short explanation
    •   AltAdvertisment
    Full Member level 6
    Jul 2006
    USA
    387
    4,159
    15
    Wz is a zero location.
    I didn't know what the zero location calculation can also use the gain-bandwidth constant relationship to obtain. Thanks.
  7. #7
    Nov 2001
    US
    750
    8,910
    22
    The gain bandwidth relation just relates two frequencies on a + or - 20db/dec response. It doesn't care if you call one frequency a zero or a pole or just pick two frequencies on the slope.
