Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
  1. #21
    Junior Member level 3
    Points: 1,926, Level: 10
    Aug 2009
    England
    26
    1,926
    10
    Re: Tube filaments on 230v? What do I need to know?
    Quote Originally Posted by neazoi View Post
    I remember old television sets tubes filaments glowed brightly when the tv was switched on. Then they shut off and after a few seconds went red glow (normal operation). This is the case in almost all televisions I have seen. I do not think they worried too much for the inrush current when the filaments are cold. And I have never seen a tube filament broken from that era.
    I recently built up a hybrid valve/mosfet amplifier running of 12vdc.
    I couldn't get it to play ball and someone suggested a higher dc voltage.
    So I tried 30 volts only to suddenly realise the heaters were running off 30 volts too !
    Luckily the heaters survived it. So it looks like heaters can take a bit of abuse.
  2. #22
    Points: 14,815, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,463
    14,815
    29
    There is something additional, that was explained to me *decades ago* by a tube engineer: the maximum filament to cathode breakdown voltage.
    For instance the 12AX7 / ECC83 tube has only 180 volts peak rating, which very likely could be exceeded on a direct 230 volt line.
    The 50C5 which was designed for the "All American Five" transformerless radios, has a slightly improved margin of 200 volts peak rating. But the line voltage is only 120 volts AC.
    My batteries are recharged by "Helpful Post" ratings.
  3. #23
    Points: 259,307, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,273
    259,307
    100
    See post #16.
