Results 1 to 7 of 7
    Newbie level 3
    Points: 26, Level: 1
    May 2019
    26
    Single Cell Li-IOn/Li-Po Battery Charger IC
    We have requirement for the single cell 3.7V Li-ion/Li-Po battery charger with inbuilt over charge and discharge protection. And we also need the Buck and boost converter for the regulated output voltage ( 3.3V and 4V) at the output end. The input charger supply is 5V micro USB.
    This regulated power supply will be used for ESP32 nodemcu and GSM sim880C. The SIM880C will required 4V and 2mA burst current on power up and nodemcu will be operated on 3.3V.
    We came across with the TI BQ25606 Battery Charger IC, does this IC suits the requirement of over charge and under discharge protection with buck and boost converter?
    Can you suggest us other battery charger IC with given specification?
    •   AltAdvertisment
    Full Member level 6
    Points: 2,170, Level: 10
    Aug 2016
    369
    2,170
    10
    Re: Single Cell Li-IOn/Li-Po Battery Charger IC
    No, the TI BQ25606 does not suit the requirement. It has only one switch port. Search for a buck-boost power management IC. IC's in that category fit your application.
    --Akanimo.
    •   AltAdvertisment
    Newbie level 3
    May 2019
    26
    Can you suggest us any Power management IC with buck boost converter part ? OR
    Is there any buck boost converter part can be used seperately with the TI BQ25606 or any other Battery charger IC?
    •   AltAdvertisment
    Points: 73,838, Level: 66
    Apr 2014
    14,978
    73,838
    66
    If i need to find a part, then I'd go to the IC manufacturers or distributors internet site and use their interactive selection guides.
    They usually are easy to use, most up to date, with most information in a short time.
    Newbie level 3
    May 2019
    26
    The SIM880C will require 4V and 2A burst current on power up.
    •   AltAdvertisment
    Full Member level 6
    Aug 2016
    369
    2,170
    10
    Look up these options.
    https://www.digikey.com/products/en/...=1&pageSize=25
    I've filtered to only ICs that can control buck-boost converters. Make a choice from there.
    --Akanimo.
  7. #7
    Advanced Member level 3
    Points: 5,363, Level: 17
    kripacharya's Avatar
    Dec 2012
    New Delhi
    965
    5,363
    17
    Use TP4056 based modules
