Application interface for Nvram
electronicsman
Full Member level 5
I have this clarification i want to write application interface for nvram. The doubt is does the application needs to know the eeprom address where he is writing? How to implement such a logic where the same application is reading the data, i should read from the same location. Any sample code available?
what NVRAM are you talking about? Type, manufacturer, datasheet
The interface most probably will be SPI, I2C, parallel, ...
Please read the datasheet and in your next post please refer to the datasheet (page section...)
...and I would add that unless this is a one byte NVRAM, yes, you need to be able to specify addresses.
