Results 1 to 2 of 2
    Newbie level 1
    Points: 78, Level: 1
    Feb 2019
    78
    [moved] OFDM Index modulation (code gives wrong result)
    can someone tell me what is wrong with my code, the result is incorrect
    place this code first on a different file first for the function
    function table2=BPSKAA(table2)
    table2=[[1;0;1;0],[1;0;-1;0],[-1;0;-1;0],[-1;0;1;0],[0;1;0;1],[0;1;0;-1],[0;-1;0;-1],[0;-1;0;1],[1;0;0;1],[1;0;0;-1],[-1;0;0;-1],[-1;0;0;1],[0;1;1;0],[0;1;-1;0],[0;-1;-1;0],[0;-1;1;0]];
    end
    clc
    clear all;
    close all;
    % rand('seed',183);   randn('seed',321);
     %% MODEULATION AND DEMODULATION OBJECT BPSK
     M = 2;
           Eac = 2;
      taps=10;
          SNR = 0:2:40;               % signal-to-noise ratio in dB
           No = (Eac)*10.^(-SNR/10);  % noise variance
         L_SNR = length(SNR);         % length of SNR
           ber = zeros (L_SNR,1);     % initializating BER
           Result_table=zeros(4 ,128);
          %  bit_RL=zeros(L_SNR,1);
     Nframe=10000;
      bit_RL=zeros(21,1);
    %digMod1=zeros(2 , length(digMod));
    %% ============================= Transmitter ===============================
     for iL=1:Nframe % sending 1000 frame
    bit_T= randi([0 1],512,1);     % generate random bits
    G_bits = reshape(bit_T,4,128);    % grouping bits into blocks
    %% taking the first two rows for index modulation selection
    Index_selection=  [G_bits(1:2,:)].';
    %% Doing BPSK modulation for third and fourth rows for G_bits
    AW=reshape(G_bits(2+1:end,:),1,[]);
    digMod1 = 2*(AW)-1;
    digMod=reshape(digMod1,2,[]);
    % digMod = 2*(G_bits(2+1:end,:))-1;
    %% Create a block 4x128 to add result for BPSK modulation depending on sub carrier position
      block = zeros(4 , length(digMod));
    ab=  zeros(2 , 128);
    % ML = zeros(1,16);
    %% Chosing which sub carrier active in each colum
     for i=1:length(Index_selection)
    if Index_selection(i,1:end)==[0 0]
        sub_no(i,1:2)=[1,3];
    elseif Index_selection(i,1:2)==[0 1]
        sub_no(i,1:2)=[2,4];
    elseif Index_selection(i,1:2)==[1 0]
        sub_no(i,1:2)=[1,4];
    elseif Index_selection(i,1:end)==[1 1]
        sub_no(i,1:2)=[2,3];
    end
    %% Adding the modulated signal on active carriers
    block(sub_no(i,1:2) , i)=digMod(1:2,i);
     end
    transmitted_signa =block; % transmitted_signal
    %% Pass the signal through IFFT
     transmitted_signa1=reshape(transmitted_signa,512,1);
     IFFT_data = ifft(fftshift(transmitted_signa1.')).';
     a=max(max(abs(IFFT_data)));
     transmitted_signa_IFFT=IFFT_data./a; % normalization
     %% % transmitted sinal with IFFT
    transmitted_signa_IFFT=reshape(transmitted_signa_IFFT,4,128);
    %% Appending cylic prefix
    % transmitted_signa_IFFT2 = [transmitted_signa_IFFT(:,[112128]) transmitted_signa_IFFT];
       transmitted_signa_IFFT=reshape(transmitted_signa_IFFT,512,1);
    %% Calling a table for all posible position for BPSK modulation in INdex modaulation
     table=BPSKAA;
    %   for iL=1:Nframe
    %% Creating a channel and receiver
    ber=[];
       for  ii  =1: L_SNR
              % for pp = 1 :128
      %% Creating  channel  and noise
       ch = sqrt(.5)*( randn(1,1,1) + 1i*randn(1,1,1));
    % %   ch=sqrt(.5)*(randn(1,1)+j*randn(1,1));
      noise = sqrt(.5)*(randn(1 , 1) + 1i*randn(1 , 1))* sqrt(No(ii));
    % % noise =awgn(xt,SNR(ii),'measured');
      %% Passing signal through noise amd channel
            received_signal = ch.*transmitted_signa_IFFT;
    %         received_signal=awgn(received_signal,SNR(ii));
     %% removing cyclic prefix
    %  received_signal = received_signal(:,[33:160]);
    %% Applying FFT and normalize the signal
    %  received_signal=reshape(received_signal,4,128);
    received_signal1  = a.*fftshift(fft(received_signal.' )).';
    received_signal2=reshape(received_signal1,4,128);
        for pp= 1 : 128
       %% Maximum Likelihood
       ML = zeros(1,16);
    A=received_signal2(:,pp);
    B= repmat(A,[1,16]);
    %  AAA=awgn(table,SNR(ii));
     ML= sum(abs( (B) - (ch.*table).^2));
                 [temp1 temp2] = min(ML);
                      KL(pp)=temp2;
      %% finding which sub carrier active in each colum
      if  (  KL(pp)>=1 &&   KL(pp)<=4)
        P_sub_B(pp,1:2)= [1,3];
        GET_INDEX_Selec(pp,1:2)=[0,0];
    elseif (  KL(pp)>=5 &&   KL(pp)<=8)
         P_sub_B(pp,1:2)=[2,4];
         GET_INDEX_Selec(pp,1:2)=[0,1];
    elseif  (  KL(pp)>=9 &&   KL(pp)<=12)
         P_sub_B(pp,1:2)=[1,4];
         GET_INDEX_Selec(pp,1:2)=[1,0];
    elseif (  KL(pp)>=13 &&   KL(pp)<=16)
         P_sub_B(pp,1:2)=[2,3];
         GET_INDEX_Selec(pp,1:2)=[1,1];
      end
     AC_subcarrier=P_sub_B;
     %%chosing the two colum for the postion os subcarrier
     %% Demodulate the transmiited_signal using the  Index selection bits you detected in receiver after you chose for the first colum
        ab(1:2,pp)= (transmitted_signa(AC_subcarrier(pp,1:2),pp));
       % converting modulated values into 0 and 1
       bi_demod(1:2,pp) = ( (ab(1:2,pp))+1)/2 ;
    %     bi_demod(1:2,pp) = ( (ab(1:2,pp))+1)/2 ;
    %    bi_demod(1:2,pp)=demodulate(modem.pskdemod(2),ab(1:2,pp));
     %% Creating a Result_table 4x128 after you detected the INdex selection bits and demodulated signal bits
         GET_INDEX_Selec1=GET_INDEX_Selec(pp,1:2).';
          bi_demod1= bi_demod(1:2,pp);
      Result_table(:,pp)=[   GET_INDEX_Selec1;  bi_demod1];
       end
    bit_R=reshape( floor(Result_table),512,1);
     [~,ber(ii,1)] = biterr(bit_T(:,1),bit_R(:));
    % [number,ratio(ii,1)] = symerr(bit_T(:,1),bit_R(:),'row-wise');
       end
    bit_RL= bit_RL+ ber;
    %% Adding the previous ber for thw previous frame with the next frame after it
     end
     bit_RL=bit_RL/Nframe;
    Newbie level 2
    Points: 18, Level: 1
    Aug 2019
    18
    Re: [moved] OFDM Index modulation (code gives wrong result)
    Perhaps, the following Python implementation would help your understanding.
    https://ishikawa.cc/imtoolkit/tutori...leigh-BER.html
