Zak28
Advanced Member level 2
Recently tried to get a spark gap to break over using spark plug shortened to closer than 1mm with 390v by placing SR-90 and Po-210 in the vicinity of the gap. Then after a short duration the high voltage filter capacitor on the inexpensive boost 390v module was destroyed then flamed out, the can was propelled outwards with no safety vent functioning.
I didn't measure the 12v input current to module to determine if the isotopes caused the gap to break over but it seemed either isotopes caused emi noise in the module or the gap did infact break over. Could the isotopes induce a form of EMI or other noise which would damage the capacitors? The isotopes from www.spectrumtechniques.com and were at least 8 inches away from the module. Might replace the damaged capacitors to repeat this and measure input current to the module when isotopes are in vacinity to the gap.
