Results 1 to 6 of 6
    Points: 321, Level: 3
    Feb 2019
    42
    321
    I need help understanding measurements / dimention markings on a datasheet
    Hi all,
    So I am trying to draw a package for a micro SD card holder from Molex however I cannot quite understand some of the markings.
    For example some markings are simple 1.8 meaning 1.8mm however others are for example 2-5.14... or 2-1.0... what does it mean?
    https://static6.arrow.com/aropdfconv...0310831_sd.pdf
    Thank you
    Points: 260,308, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,460
    260,308
    100
    Re: I need help understanding measurements / dimention markings on a datasheet
    Consider that the N-xx.x syntax refers to dimensions occurring multiple times. In case of 2-5.14 this is a bit confusing because 5.14 is also printed separately for the upper pin.
    You could also consider that the picture is the copy of a correctly dimensioned CAD drawing. So you can always scale it accordingly and check the dimensions with a ruler, or even convert it to dxf and use it to check your footprint pin placement.
    Full Member level 6
    Points: 2,037, Level: 10
    Jan 2019
    379
    2,037
    10
    i don't think that drawing is correctly dimensioned
    the current practice is to measure everything from one reference, usually the lower left
    so that tolerances do not build up
    the values in the drawing are likely correct, as Molex is reliable, but the drawing does not follow best practices
    as for the drawing being a copy, it looks like a small piece of the drawing in the link
    there is no reason to believe photocopies and PDFs maintain dimension
    if you measure the drawing, start by checking several short dimensions and several long dimension in both directions
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,460
    260,308
    100
    Should be so, but incremental dimensions seem to be popular, particularly in Japanese and Chinese data sheets. No reason to assume that the dimensions are wrong.
    You can download a STEP 3D-file from Molex and export it to *.dxf
    Should give you exact dimensions.
    Feb 2019
    42
    321
    Ureka moment! 8-1.1 means qty 8, size 1.1mm
    Points: 12,693, Level: 27
    Feb 2010
    UNITED KINGDOM
    1,985
    12,693
    27
    Better still read the DXF into your cad package and use as a base for the component.
