Results 1 to 11 of 11
    Newbie level 3
    Points: 22, Level: 1
    Apr 2019
    22
    Verilog beginner: is synthetized rtl optimal?
    For that source code:
    module top(input clk, input led, output to_port1,output [24:0] to_port2);
        reg ctr = 0;
    	reg[24:0] counter = 2;
        always@(posedge clk) begin
    		if (ctr == 1) begin
    			ctr <= 0;
    			counter <= counter + 1;
    		end
    		else
    			ctr <= 1;
        end
        assign led = ctr;
    	assign to_port1 = led;
    	assign to_port2 = counter;
    endmodule
    I used Yosys to generate rtl. It gave me this:
    /* Generated by Yosys 0.8 (git sha1 UNKNOWN, clang 7.0.2 -fPIC -Os) */
    (* src = "x.v:1" *)
    module top(clk, led, to_port1, to_port2);
      (* src = "x.v:5" *)
      reg [24:0] _0_;
      (* src = "x.v:5" *)
      reg _1_;
      (* src = "x.v:4" *)
      reg [24:0] _2_;
      (* src = "x.v:3" *)
      reg _3_;
      (* src = "x.v:8" *)
      wire [31:0] _4_;
      (* src = "x.v:6" *)
      wire _5_;
      (* src = "x.v:1" *)
      input clk;
      (* src = "x.v:4" *)
      reg [24:0] counter;
      (* src = "x.v:3" *)
      reg ctr;
      (* src = "x.v:1" *)
      input led;
      (* src = "x.v:1" *)
      output to_port1;
      (* src = "x.v:1" *)
      output [24:0] to_port2;
      assign _4_ = counter + (* src = "x.v:8" *) 32'd1;
      assign _5_ = ctr == (* src = "x.v:6" *) 32'd1;
      always @* begin
        _3_ = 1'h0;
      end
      always @* begin /*useless?*/
      end
      always @({  }) begin
          ctr <= _3_;
      end
      always @* begin
        _2_ = 25'h0000002; /* proper way to initialize a value?
      end
      end
      always @({  }) begin
          counter <= _2_; /* _2_ is always equal to 2, no?*/
      end
      always @* begin
        _1_ = ctr;
        _0_ = counter;
        casez (_5_) /* counter overflow management */
          1'h1:
            begin
              _1_ = 1'h0;
              _0_ = _4_[24:0];
            end
          default:
              _1_ = 1'h1;
        endcase
      end
      always @(posedge clk) begin
          ctr <= _1_;
          counter <= _0_;
      end
      assign led = ctr;
    endmodule
    I annotated the code so that you can see where my interrogations lie.
    Would you consider it is a reasonable rtl code?
    Points: 8,896, Level: 22
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,332
    8,896
    22
    Blog Entries
    Re: Verilog beginner: is synthetized rtl optimal?
    I think you should spend some more time with your Verilog.
    You are assigning the value of a register to an input port?
    assign led = ctr;
    Did you try to compile your code before this Yosis stuff?
    It would be meaningless to do synthesis with error RTL.
    FPGA enthusiast!
    Newbie level 3
    Apr 2019
    22
    You are right. Overlooked that.
    Here is the corrected code and the new synthesis:
    module top(input clk, input led, output led2, output to_port1,output [24:0] to_port2);
        reg ctr = 0;
    		if (ctr == 1) begin
    			ctr <= 0;
    		end
    		else
    			ctr <= 1;
        end
        assign led2 = ctr;
    endmodule
    module top(clk, led, led2, to_port1, to_port2);
      reg [24:0] _0_;
      reg _1_;
      reg [24:0] _2_;
      reg _3_;
      wire [31:0] _4_;
      wire _5_;
      input clk;
      reg [24:0] counter;
      reg ctr;
      input led;
      output led2;
      output to_port1;
      assign _4_ = counter + 32'd1;
      assign _5_ = ctr == 32'd1;
      always @* begin
        _3_ = 1'h0;
      end
      always @* begin
      end
      always @({  }) begin
          ctr <= _3_;
      end
      always @* begin
        _2_ = 25'h0000002;
      end
      always @* begin
      end
      always @({  }) begin
          counter <= _2_;
      end
      always @* begin
        _1_ = ctr;
        _0_ = counter;
        casez (_5_)
          1'h1:
            begin
              _1_ = 1'h0;
              _0_ = _4_[24:0];
            end
          default:
              _1_ = 1'h1;
        endcase
      end
          ctr <= _1_;
          counter <= _0_;
      end
      assign led2 = ctr;
    endmodule
    So, the problem is that it generates empty lists
    This @* expands to empty list, will never wake up.
    So basically, the rtl is not good when the original code simulates just fine. Where did I messed up?
    dpaul's Avatar
    Jan 2008
    Germany
    1,332
    8,896
    22
    Blog Entries
    First please tell me what is your need, your target.
    Are you trying to <1> write a good RTL or <2> are you trying to test the Yosys tool for a good netlist generation?
    If <1>, you should be writing a test-bench and performing functional verification of your design through simulation.
    If <2>, You can easily get a correct and properly coded simple 'counter' code from the internet and use it with Yosys.
    FYI - I rarely take a look into synthesized netlist files and this is the first time I am hearing about this Yosys.
    FPGA enthusiast!
    Newbie level 3
    Apr 2019
    22
    Thanks Dpaul, I am just tinkering with the tool, throwing random code at it..
    Points: 38,501, Level: 47
    Jun 2010
    6,962
    38,501
    47
    Writing better RTL that is easy to understand is more important than what it ends up looking like.
    Hard to understand but "clever" RTL is more likely to get thrown away by others.
    Learn to write RTL, and the circuit improvement should come with it.
  7. #7
    dpaul's Avatar
    Jan 2008
    Germany
    1,332
    8,896
    22
    Blog Entries
    ...throwing random code at it.
    I think you should be first putting in good quality and verified RTL (there are many trusted sources, Google) and use them.
    Then for playing around and see how the tool is behaving, you can try throwing in bad RTL.
    Remember one thing, if you are posting here netlists and its corresponding RTL, and asking us to evaluate the netlist quality, that is not feasible. As I have mentioned before, design engineers rarely look inside a netlist.
    FPGA enthusiast!
  8. #8
    Points: 9,228, Level: 22
    Apr 2016
    1,924
    9,228
    22
    Why is the output of synthesis not a netlist? What am I missing here?
    Really, I am not Sam.
  9. #9
    Points: 32,407, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,492
    32,407
    43
    Quote Originally Posted by ThisIsNotSam View Post
    I know it looks more like obfuscated RTL with all the "_1_" translated names.
    Netlists never have always, case, or other behavioral code keywords.
  10. #10
    Points: 7,908, Level: 21
    Jul 2010
    Sweden
    1,061
    7,908
    21
    It looks like the first synthesis stage, independent of hardware/architecture.
  11. #11
    Apr 2016
    1,924
    9,228
    22
    Quote Originally Posted by std_match View Post
    you mean a generic netlist? it can't be, it still is RTL, not gate level.
