Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
    Full Member level 4
    Points: 2,386, Level: 11
    Aug 2011
    197
    2,386
    11
    EM field around Current Transformer
    Hi
    I am receiving input current in the range 0-50A, 50 Hz AC current. I have a 1000/1 CT. Nearby , I have Downstream electronics consisting of ADC and MCU for displaying the input current. The question is, can AC current produce sufficient EM field to damage ADC and MCU?
    Points: 79,050, Level: 68
    Apr 2014
    16,045
    79,050
    68
    Re: EM field around Current Transformer
    impossible to answer.
    Generally: for every I/O that leaves/enters the PCB (or the device) you need to consider ESD protection and EMI/EMC filters.
    If you are not sure, then add one.
    If cost is a problem then ask the customer for EM field specification.
    Full Member level 4
    Aug 2011
    197
    2,386
    11
    For CT secondary , I do have a protection diodes in shunt along with the resistor. My question is can current in primary cause sufficient EM field to damage the electronics?
    Points: 15,100, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,507
    15,100
    29
    You would have to provide the datasheet, or at the very least a good photo, of your current transformer.
    Most toroids contain the stray fields pretty good.
    My batteries are recharged by "Helpful Post" ratings.
    Full Member level 4
    Aug 2011
    197
    2,386
    11
    Hi
    CT data sheet https://www.mouser.in/datasheet/2/192/CT07-1003158.pdf. Please advice for the precautions to be taken
    Points: 261,937, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,781
    261,937
    100
    Wrong question. If at all, the field of the primary conductor would be the problem. The CT core can reduce but not increase the field.
    The induced voltage around a 50A 50Hz conductor is quite low.
  7. #7
    Full Member level 4
    Aug 2011
    197
    2,386
    11
    Hi FvM
    The datasheet says that secondary inductance is around 8H. Will it not create EM field?
  8. #8
    Points: 11,906, Level: 26
    Aug 2015
    Melbourne
    1,950
    11,906
    26
    no, not if it has a low value R across it completing the circuit. The mag field cannot dmage your ckt - only a high fault current giving a high voltage on the CT output - or if the burden R goes Hi-Z or open circuit...
  9. #9
    Apr 2014
    16,045
    79,050
    68
    Current causes magnetic field. In a CT the primary is just one winding, thus the magnetic field will not higher than without CT. But in the CT the magnetic field is concentrated in it's core. And the magnetic field in the core causes current in the secondary of the CT. This current again causes the magnetic field within the core to be compensated. It becomes reduced, but not completely to zero.
    The magnetic field outside the core will cause about no current in the secondary.
  10. #10
    Full Member level 4
    Aug 2011
    197
    2,386
    11
    I got my ADC damaged in two boards after injecting currents (after approx ten iterations). The ADC is about 100mm distance from the primary wire. Input currents were in the order 0-10A, 50 Hz AC.
  11. #11
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,781
    261,937
    100
    Most likely the unclamped CT sensor output voltage has been routed to the ADC. Please show a schematic.
  12. #12
    Apr 2014
    16,045
    79,050
    68
    I agree with FvM.
    Wrong usage / wrong circuit.
    Show your schematic.
  13. #13
    Aug 2015
    Melbourne
    1,950
    11,906
    26
    Perhaps the OP doesn't know the CT must be terminated with a suitable resistor 1000:1 CT 50A thru middle => 50mA on 10 ohm this is 500mV and 0.025VA
    if you have 10k input impedance - rather than a low ohm burden resistor - the volts will be 500V ...!
  14. #14
    Full Member level 4
    Aug 2011
    197
    2,386
    11
    No, It is 2 ohms burden. It works for a while and then suddenly everything fails.
  15. #15
    Aug 2015
    Melbourne
    1,950
    11,906
    26
    faulty soldering or component or connection when moved.... ?
    put some big diodes ( 10A10 ) in inverse parallel across CT LV terminals this will limit the V to 600mV peak
  16. #16
    Apr 2014
    16,045
    79,050
    68
    Hi
    It's still the same:
    Either schematic or PCB layout problem.
  17. #17
    Aug 2015
    Melbourne
    1,950
    11,906
    26
    cracked 2 ohm SMT resistor ... ?
  18. #18
    Full Member level 4
    Aug 2011
    197
    2,386
    11
    Some discovery from my side, but I need confirmation. I have transformer based current injection kit, which shares the same distribution board,from where I tap 230V to power my board ( through AC-DC converter). I am guessing that some form of inrush lifting neutral voltage might have caused my board to fail. Is it possible?
    Anycase, the schematics is provided below, TVS diode used is SMBJ5V0CA ( input current range 1-50A, output of CT 2mV-100mV RMS, 2 Ohm in shunt)
  19. #19
    Aug 2015
    Melbourne
    1,950
    11,906
    26
    try some 100nF 250Vac caps to earth on each line ...
    what is FB1 & 2 ..?
  20. #20
    Apr 2014
    16,045
    79,050
    68
    You make the thread (and to get a solution) unnecessary lengthy.
    It seems you donīt want to get a solution ... why else do you give the requested informations slowly piece by piece?
    This little snippet of schematic is not useful. --> show the complete circuit of the signal chain from CT to ADC including PCB layout. With all connections involved.
