Results 1 to 4 of 4
    Newbie level 5
    Points: 51, Level: 1
    Apr 2019
    10
    51
    Digital pin as TXD , RXD.
    Can i use the digital pin of microcontroller as serial (TXD, RXD) ??
    •   AltAdvertisment
    Points: 78,733, Level: 68
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,892
    78,733
    68
    Re: Digital pin as TXD , RXD.
    You can use any pin of a microcontroller to read or send serial data if you program it appropriately. If the microcontroller has a UART module it is usually easier to use it instead of using software but they normally constrain the UART connection to fixed pin numbers.
    •   AltAdvertisment
    Newbie level 5
    Apr 2019
    10
    51
    how should i program it. is there a specific flow for making digital pin, a UART.
    •   AltAdvertisment
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    12,892
    78,733
    68
    A UART is a specific device within most microcontrollers, you need to consult the data sheet to see how to use it.
    If you want to use any other pin for serial communication you have to write your own software to do it, we call it a 'software uart' or a 'bit-banged uart'. Your program is responsible for performing all the timing and shifting between serial and parallel streams. How to do it depends on which MCU you are using and to some extent what other things it also has to do. Software UARTs require precise timing so it often isn't feasible to use one if other demands are made on the MCUs resources.
