Digital phase lead in MCU
curious_mind
Full Member level 4
Hi
I have two input signals A and B , which are sinusoidal in nature. All that I have to do is to ensure that both signals are exactly in phase. I have observed that A lags B by 1 degree. How do I compensate this in MCU?
sinusoidal signals are analog signals, but your MCU is a digital device. Thus I assume there is an ADConverter involved.
--> for a detailed answer you need to provide the information about your complete signal chain.
For now I can give only a general answer: lag signal B by 1 degree.
Hi
I use a Simultaneous sample ADC in between the signal and MCU. How do I lag signal B by 1 degree. Any sample c code ?
No values, how can you expect a good advice?
--> delay it by a sufficient count of ADC samples.
Honestly. We don´t know nothing. We don´t know whether 1 degree means 1000 samples or 1/1000 of a sample.
Hi
Input signals are 50Hz, sampling frequency is 2500 Hz. How to delay the samples?
May I ask why you don't show a little effort of your own to motivate members to spend time for you?
At least two values.
Did you calculate the delay time?
Td = phase_angle / ( frequency × 360°)
Or sampling period time?
Ts = 1 / f_sample
..to get to know whether it is more or less of a sample period
A bit of additional information could help also: why not using an analog filter. What's the application. How did you measure the 1°?...
Hi
I measured 1 degree through the oscilloscope (phase1-phase2). Can we digitally phase shift?
