Results 1 to 5 of 5
    Advanced Member level 1
    Points: 4,294, Level: 15
    Jul 2006
    USA
    402
    4,294
    15
    Voltage reading is not constant from DAQ
    I have the NI6259 and want to read an analog signal.
    I connect DC voltage 0.35V to the AI0 analog input pin of NI6259 through a BNC connector. The ground pin of the signal generator is connected to the ground pin of the BNC adapter.
    The measured signal is oscillating. Could anyone help to explain? It should be a constant voltage. Thank you.
    Points: 77,099, Level: 67
    Apr 2014
    15,620
    77,099
    67
    Re: Voltage reading is not constant from DAQ
    obviously 60Hz mains frequency.
    Loop via Earth_GND?
    Your pictures and description donīt give much information. Itīs just a snippet of all the devices and connections involved
    For example: where is the "0.35V" coming from and where itīs power is coming from, what cbles, what length and how they are installed.....
    Jul 2006
    USA
    402
    4,294
    15
    Thanks you. When I connects it with the differential mode, when there is no ripple.
    Points: 19,003, Level: 33
    crutschow's Avatar
    Feb 2012
    L.A. USA Zulu -8
    3,665
    19,003
    33
    Quote Originally Posted by shanmei View Post
    Then why not run it in the differential mode.
    Please give us more info on what you are doing, so we can avoid a game of 20 questions.
    Zapper
    Curmudgeon Elektroniker
    Jul 2006
    USA
    402
    4,294
    15
    In the DAQ software setup, I set the terminal configuration to be " differential", then the measured signal is stable without the ripple.
