Spartan6 (ISE 14.7) how to generate differential clock?
FlyingDutch
Advanced Member level 1
Bydgoszcz - Poland
I would like to ask: How to generate differential (two lines) clock from "normal" clock (one line). The clock frequency is 100 MHz. Project is written in Verilog and I am using
"ISE Webpack 14.7" (Windows10 Pro) for synthessis. My FPGA is Spartan6 (XC6SLX9 in CSG324 package) on Mimas V.2 board (Numato).
Thanks in advance and Regards
By choosing a suitable differential output pin pair and the respective differential IO standard in constraint editor.
I thought that differential clok is consisted from two signal lines. Signal on second line is square wave shifted in phase for 180 degrees in relation to signal on first line.
I know that in user constraint files are appropriate standards for this (for example DIFF_MOBILE_DDR).
If i have one line clock from PLL, I don't need to generate second signal? I am a bit confusing now, could you clarify this question?
Thanks nad Regards
The inverted signal is generated in IO cell, the usual way is to have one output signal (e.g. a top level port of your design) and assign a differential IO standard to it. I have only cursory knowledge of Xilinx tools, but I have seen this method used with it.
Alternatively, there may be an option to instantiate a differential driver low level primitive explicitly, but it doesn't bring any advantage in usual cases.
An OBUFDS Xilinx primitive might suite your purpose.
I would suggest you to read the realted "SelectIO Resources" docu for Series6 Xilinx FPGA for details.
This thread might help : http://forums.xilinx.com/t5/Spartan...a-differential-output-for-a-clock/td-p/100268
I placed in my Verilog code OBUFDS instance like that:
wire CLOCK_OUT_P,CLOCK_OUT_N;
  CLKWizard CLKGEN
   (// Clock in ports
    .CLK_IN1(Clk100Mhz),
    // Clock out ports
    .CLK_OUT1(clkAXIOut),    //50 MHz AXI clock
    .CLK_OUT2(clkVGAOut),    //25.175 MHz VGA clock
    .CLK_OUT3(clkBuf100MHz), //100 MHz DDR memory clock
    // Status and control signals
    .RESET(io_asyncReset),
    .LOCKED(clkLOCKED));
	 //buf clkBuffer(clkBuf100MHz,clkDDR100MHz);
  OBUFDS #(
  .IOSTANDARD("DIFF_MOBILE_DDR")
  ) OBUFDS_01 (
   .O(CLOCK_OUT_P),
   .OB(CLOCK_OUT_N),
   .I(clkBuf100MHz)
and project (ISE 14.7) implements without errors, so I assume that it is all right.
Thanks for help and Regards
If there are no more problems then it is time to close the thread! :)
