Results 1 to 7 of 7
    Full Member level 2
    Points: 1,077, Level: 7
    FlyingDutch's Avatar
    Dec 2017
    Bydgoszcz - Poland
    134
    1,077
    7
    Spartan6 (ISE 14.7) how to generate differential clock?
    I would like to ask: How to generate differential (two lines) clock from "normal" clock (one line). The clock frequency is 100 MHz. Project is written in Verilog and I am using
    "ISE Webpack 14.7" (Windows10 Pro) for synthessis. My FPGA is Spartan6 (XC6SLX9 in CSG324 package) on Mimas V.2 board (Numato).
    Thanks in advance and Regards
    Points: 261,068, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,606
    261,068
    100
    Re: Spartan6 (ISE 14.7) how to generate differential clock?
    By choosing a suitable differential output pin pair and the respective differential IO standard in constraint editor.
    Full Member level 2
    Dec 2017
    Bydgoszcz - Poland
    134
    1,077
    7
    I thought that differential clok is consisted from two signal lines. Signal on second line is square wave shifted in phase for 180 degrees in relation to signal on first line.
    I know that in user constraint files are appropriate standards for this (for example DIFF_MOBILE_DDR).
    If i have one line clock from PLL, I don't need to generate second signal? I am a bit confusing now, could you clarify this question?
    Thanks nad Regards
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,606
    261,068
    100
    The inverted signal is generated in IO cell, the usual way is to have one output signal (e.g. a top level port of your design) and assign a differential IO standard to it. I have only cursory knowledge of Xilinx tools, but I have seen this method used with it.
    Alternatively, there may be an option to instantiate a differential driver low level primitive explicitly, but it doesn't bring any advantage in usual cases.
    Points: 8,521, Level: 22
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,276
    8,521
    22
    Blog Entries
    An OBUFDS Xilinx primitive might suite your purpose.
    I would suggest you to read the realted "SelectIO Resources" docu for Series6 Xilinx FPGA for details.
    This thread might help : https://forums.xilinx.com/t5/Spartan...ck/td-p/100268
    FPGA enthusiast!
    Full Member level 2
    Dec 2017
    Bydgoszcz - Poland
    134
    1,077
    7
    Quote Originally Posted by dpaul View Post
    I placed in my Verilog code OBUFDS instance like that:
    wire CLOCK_OUT_P,CLOCK_OUT_N;
      CLKWizard CLKGEN
       (// Clock in ports
        .CLK_IN1(Clk100Mhz),
        // Clock out ports
        .CLK_OUT1(clkAXIOut),    //50 MHz AXI clock
        .CLK_OUT2(clkVGAOut),    //25.175 MHz VGA clock
        .CLK_OUT3(clkBuf100MHz), //100 MHz DDR memory clock
        // Status and control signals
        .RESET(io_asyncReset),
        .LOCKED(clkLOCKED));
    	 //buf clkBuffer(clkBuf100MHz,clkDDR100MHz);
      OBUFDS #(
      .IOSTANDARD("DIFF_MOBILE_DDR")
      ) OBUFDS_01 (
       .O(CLOCK_OUT_P),
       .OB(CLOCK_OUT_N),
       .I(clkBuf100MHz)
    and project (ISE 14.7) implements without errors, so I assume that it is all right.
    Thanks for help and Regards
  7. #7
    dpaul's Avatar
    Jan 2008
    Germany
    1,276
    8,521
    22
    Blog Entries
    If there are no more problems then it is time to close the thread!
    FPGA enthusiast!
