Results 1 to 4 of 4
    Points: 70, Level: 1
    Mar 2019
    70
    Problem in Designing of SAR ADC
    Hi team
    I am designing SAR adc . I am finding trouble in designing switches in dac charge redistribution circuit.I am using cadence virtuoso and I know that I can use the direct SPDT switch from analog lib,but I want to design it by using mosfets. Can anyone help me in this task?
    I am designing 4 bit SAR adc.I am attaching circuit over here for more clearance.
    Thank youClick image for larger version.
Name:	charge redistribution.PNG
    Advanced Member level 3
    Points: 9,195, Level: 22
    Nov 2001
    US
    786
    9,195
    22
    Re: Problem in Designing of SAR ADC
    How about something like this? Depending on your input range you may not need a transmission gate.
    Points: 257,401, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,915
    257,401
    100
    I guess the library SPDT switches are CMOS switches with respective drivers. If you want similar performance, there's no more simple circuit alternative.
    If you want to avoid library usage, sketch circuit yourself.
    Nov 2001
    US
    786
    9,195
    22
    analogLib components are ideal
