Results 1 to 7 of 7
    Newbie level 3
    Points: 32, Level: 1
    Apr 2019
    32
    3D EM interface to electrical circuits
    The amount of energy that a wire receives (or emits) depends on its impedance. This impedance is a function of the environment around the wire. A wire laid out above the ground plane is an example of this dependency. If we change the distance to the GND plane, the current flowing in the wire (i.e. during emissions) will change. This impedance is generally different from antenna's impedance. CST microwave/DS does not show this impedance, at least explicitly. Is there any 3D EM simulation that can give this impedance? I want to use it directly in pspice.
    Points: 13,110, Level: 27
    Apr 2014
    2,026
    13,110
    27
    Re: 3D EM interface to electrical circuits
    Quote Originally Posted by JalalTN View Post
    This is a very simplified view. It is not clear what you are looking for. Are you looking at transmission line impedance basics? Radiation resistance of an antenna?
    Newbie level 3
    Apr 2019
    32
    Quote Originally Posted by volker@muehlhaus View Post
    I'm not interested in the emissions. It is a complicated EM system, not a transmission line. The system goes to a strong unwanted oscillation, at RF frequency! Seems that the oscillation is due to a combination of EM and the detail parameters of the semiconductor. Pspice is needed to address detail of semi.
    Advanced Member level 3
    Points: 5,564, Level: 17
    Dominik Przyborowski's Avatar
    Jun 2013
    Norway
    735
    5,564
    17
    Not sure whether this would be what you need, however my suggestion is to look for sigrity or momentum tool.
    Apr 2014
    2,026
    13,110
    27
    You mentioned wire, that is why I mentioned distributed circuit parameters (line impedance) rather than nodal parameters.
    I think there is no simple "this impedance" value (or concept) that will solve your analysis problem. It's really more involved than that.
    Your oscillallation might be from parasitic coupling (positive feedback across multiple stages -> EM analysis) or negative impedance (combined analysis of active + passive circuit + EM).
    Quote Originally Posted by Dominik Przyborowski View Post
    Agreed, but the key issue is the actual use of the EM tool. It seems that JalalTN isn't experienced with using EM results in circuit simulation, and looks for one magic parameter that he can plug into SPICE simulation.
    Newbie level 3
    Apr 2019
    32
    I believe CST and another software were tried with no success.
  7. #7
    Apr 2014
    2,026
    13,110
    27
    That means nothing. Unexperienced users often don't know how to apply EM tools properly. That's a typical mistake by many groups starting to do EM: they think they just need to buy the tool and have accurate results with no training and no experience.
    What you describe sounds like a typical problem that many other have solved successfully.
