Results 1 to 5 of 5
    Advanced Member level 2
    Points: 2,857, Level: 12
    baileychic's Avatar
    Aug 2017
    563
    2,857
    12
    TM4C123G code problem
    I am using TI Tiva launchpad and my Blinky code is not working.
    This is th elaunchpad I am using.
    https://www.anandtronics.com/EK-TM4C...chpad-eval-kit
    Oscillator and other project settings are fine because I copied them from mikroe MINI-M4-Tiva example Blink project.
    https://www.mikroe.com/mini-tiva
    I also tried to blink the onboard RGB Leds but none of the Leds light up. If I flash some other example projects written in Keil, they work and so the hardware setup is fine.
    What is the issue?
    Find my mikroC PRO ARM project attached.
    Here is my mikroC PRO ARM code.
    void main() {
        GPIO_Digital_Output(&GPIO_PORTE_DATA, _GPIO_PINMASK_ALL);
        GPIO_PORTE_DATA = 0;
        while (1) {
            GPIO_PORTE_DATA = ~GPIO_PORTE_DATA;           // Toggle LEDs
            Delay_ms(500);                                // 500ms pause
    Advanced Member level 3
    Points: 7,114, Level: 20
    Jul 2010
    Sweden
    937
    7,114
    20
    Re: TM4C123G code problem
    Enable port E before doing anything else.
    Maybe like this (not sure about the argument):
    GPIO_Clk_Enable(&GPIO_PORTE_DATA);
    baileychic's Avatar
    Aug 2017
    563
    2,857
    12
    Okay, thanks. I tried that. It still doesn't work.
    The hardware setup is okay because it works with sample code for Keil.
    Here is my latest code. The oscillator settings remain as previous (Internal Oscillator with PLL) 80 MHz.
    I made this latest code looking at the help file of mikroC PRO ARM.
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
     * Project name:
         Led_Blinking (The simplest simple example)
     * Test configuration:
         MCU:             TM4C123GH6PM
                          [url]http://www.ti.com/lit/ds/symlink/tm4c123gh6pm.pdf[/url]
         Oscillator:      IOSC-PLL, 80.000MHz
         SW:              mikroC PRO for ARM
                          [url]http://www.mikroe.com/mikroc/arm/[/url]
    void main() {
        GPIO_Config(&GPIO_PORTB, _GPIO_PINMASK_0 |
                                 _GPIO_PINMASK_1 |
                                 _GPIO_PINMASK_2 |
                                 _GPIO_PINMASK_3,
                                 _GPIO_DIR_INPUT,
                                 _GPIO_CFG_DIGITAL_ENABLE,
                                 _GPIO_PINCODE_NONE);
        GPIO_Digital_Input(&GPIO_PORTB,
                                        _GPIO_PINMASK_0 |
                                        _GPIO_PINMASK_1 |
                                        _GPIO_PINMASK_2 |
                                        _GPIO_PINMASK_3
        GPIO_PORTB_DATA = 0;
        GPIO_Config(&GPIO_PORTE, _GPIO_PINMASK_0 |
                                 _GPIO_PINMASK_1 |
                                 _GPIO_PINMASK_2 |
                                 _GPIO_PINMASK_3,
                                 _GPIO_DIR_OUTPUT,
                                 _GPIO_CFG_DIGITAL_ENABLE |
                                 _GPIO_CFG_DRIVE_8mA,
        GPIO_Digital_Output(&GPIO_PORTE_DATA, _GPIO_PINMASK_0 |
                                              _GPIO_PINMASK_1 |
                                              _GPIO_PINMASK_2 |
                                              _GPIO_PINMASK_3
        GPIO_Clk_Enable(&GPIO_PORTE);
        while (1) {
    I forgot to mention that with the latest post (post #3) I am trying to blink 4x LEDs connected to lower 4 bits of PORTE that is PE0,1,2,3. I also have 4x tact switches wired to PB0,1,2,3.
    baileychic's Avatar
    Aug 2017
    563
    2,857
    12
    Did the required changes but still not working on the launchpad.
    Changes: Moved the GPIO_Clk_Enable() calls to beginning but still not result on hardware.
    I am using "LM Flash Ultility" to download the .hex file to the launchpad.
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
     * Project name:
         MCU:             TM4C123GH6PM
    void main() {
        GPIO_Clk_Enable(&GPIO_PORTB);
                                 _GPIO_PINMASK_1 |
                                 _GPIO_PINMASK_2 |
                                 _GPIO_PINMASK_3,
                                 _GPIO_DIR_INPUT,
                                        _GPIO_PINMASK_0 |
                                        _GPIO_PINMASK_1 |
                                        _GPIO_PINMASK_2 |
                                        _GPIO_PINMASK_3
                                 _GPIO_PINMASK_1 |
                                 _GPIO_PINMASK_2 |
                                 _GPIO_PINMASK_3,
                                 _GPIO_DIR_OUTPUT,
                                              _GPIO_PINMASK_1 |
                                              _GPIO_PINMASK_2 |
                                              _GPIO_PINMASK_3
        while (1) {
    Points: 9,012, Level: 22
    Easyrider83's Avatar
    Oct 2011
    Tallinn, Estonia
    1,588
    9,012
    22
    Love me or hate me. All infractions will be ignored.
