Results 1 to 3 of 3
    Newbie level 2
    Points: 57, Level: 1
    Feb 2019
    57
    6T SRAM read/write current
    I'm having trouble finding data regarding SRAM read/write currents for 7nm nodes.
    Most of the results/data I've seen seem to be done on larger technology nodes, or on the noise margins.
    Currently, at most I've found that read/write currents are around 40~60 uA for Vdd=1V, but I think they might be too large?
    Does anyone have data off the top of their heads, or could point me to some conference/journal/roadmap where I can find the data?
    Thanks!
    Points: 8,310, Level: 21
    Apr 2016
    1,751
    8,310
    21
    Re: 6T SRAM read/write current
    Quote Originally Posted by Windywast View Post
    Thanks!
    very few people have access to 7nm, and even fewer would be in a position where they can share these values. I can tell it certainly doesn't operate at 1V, nominal voltage is <0.8V.
    Really, I am not Sam.
    Points: 39,143, Level: 48
    Mar 2008
    USA
    6,328
    39,143
    48
    Peak write current will be found at the "tipping point"
    of the core cross-coupled inverters. You could mock
    this up with min W, min L devices (although SRAM
    leaf cells are often allowed to "cheat" specific rules
    in the name of density, and you might not get to know
    (say) that the min W is less than LGRP min W unless
    you have gotten the PDK and library info from the real
    foundry).
    You might find "write charge" more useful than a write
    current, peak or averaged. Flipping over a bit (write) or
    reading a bit both act like a charge-slug per event,
    gross supply current is leakage plus these "events"
    and largely frequency dependent (as most CMOS).
    Of course in SRAM detailed design the worst case write
    current (peak) is what the write network has to source
    or sink, through the access switches, and read current
    obtainable without read turning into false write, drives
    the sense line loading, precharge and sense amp design.
    Whether this is about specification / characterization,
    or about design, is not told.
