Results 1 to 19 of 19
    Full Member level 5
    Points: 2,933, Level: 12
    May 2010
    usa
    313
    2,933
    12
    ir2110 low side problem
    i tried t he attached circuit ,ir2110 low side output is same as high side . i saw it on oscilloscope. R13 got hot and burnt, i used the circuit without connecting the meter this is the only difference . supply to the circuit is around 10v also the pll isn't affected when changing resistor value on Vcoin pin what is the problem ?
    Advanced Member level 3
    Points: 5,488, Level: 17
    Feb 2014
    778
    5,488
    17
    Re: ir2110 low side problem
    Just do one step at a time...remove power from the half bridge so nothing can burn and take your time studying the gate drive signals at each step. Going into the driver, coming out of the driver etc.
    Full Member level 5
    May 2010
    usa
    313
    2,933
    12
    signals to the driver are the same.Is this mean the 7402 ic is the problem?
    Points: 76,249, Level: 67
    Apr 2014
    15,460
    76,249
    67
    As always with power switching applications: PCB layout is critical.
    Especially if you not experienced I recommend to use one layer of the PCB as GND plane ... no other signals.
    And use proper decoupling capacitors.
    One problem that I see with your circuit is that there is no dead time control.
    Did you read the IR2110 datasheet and the application notes that are freely available at the manufacturer's internet pages?
    Full Member level 6
    Points: 1,658, Level: 9
    Jan 2019
    321
    1,658
    9
    Quote Originally Posted by mshh View Post
    signals to the driver are the same as what? each other?
    the sequence should be both sides off / low side on / both sides off / high side on / both sides off / etc
    your drive circuit appears to be low side on / swap low off high on / swap low on high off / etc
    which means both FETs can be on at the same time, during the swap
    hence the current sense resistor R13 is tied across the output of the bridge
    about 120 V RMS across 0.33 ohm, so it burns up
    what does the output go to? there is no feedback to control the output voltage.
    Feb 2014
    778
    5,488
    17
    Yes, you can't blame the driver if its being told to turn both fets on. So debug your logic, you're sure its the right part and the right pinout etc? Thinking about it really quickly the logic makes sense to me.
    Klaus the deadtime is in the pot+C on the gate inputs.
  7. #7
    Points: 9,987, Level: 23
    Aug 2015
    1,627
    9,987
    23
    Put 10uF on Vdd right by the driver, the logic seems OK - but check without the top drain connected on a scope to be sure you have dead time.
  8. #8
    Full Member level 5
    May 2010
    usa
    313
    2,933
    12
    I noticed that Hin and Lin are high at the same time and low at the same time however I simulated it on proteus and they were different and it worked as expected
    What do you mean top drain connected? The driver is good I think the problem in the logic it should output one different from another
  9. #9
    Advanced Member level 1
    Points: 2,659, Level: 12
    Aug 2016
    470
    2,659
    12
    There is certainly an issue with the 7402 gates arrangement. There is a shorter propagation delay from the 74HC4046N to Lin than there is to Hin. So there leaves an interval at transition where Lin sees a new signal but Hin is yet to see its own.
    --Akanimo.
  10. #10
    Aug 2015
    1,627
    9,987
    23
    C 8 & C9 may be too small for useful dead time - if you disconnect the top drain you can run the driver IC correctly without blowing fets and see the correct gate drive on the fet gates ... i.e. the bootstrap in the drive IC will work ...
  11. #11
    Aug 2015
    1,627
    9,987
    23
    You can use the gate on the 4046 to do the inversion - and get the two signals, then use the inputs to the IR2110 for the RC delay at turn on - this would reduce your parts count and is more robust ...
    i.e. take pin 14 high, connect pin 3 to 4, then pin 2 is the inverted GD and pin 4 is the non inverted.
  12. #12
    Full Member level 5
    May 2010
    usa
    313
    2,933
    12
    pin 14 of what. which IC do you mean?
  13. #13
    Aug 2015
    1,627
    9,987
    23
    the 4046 - per the 1st line of that post ...
  14. #14
    Full Member level 5
    May 2010
    usa
    313
    2,933
    12
    do you have any application or schematic for your proposed connection?
  15. #15
    Aug 2015
    1,627
    9,987
    23
    Why yes, I have used it to control a 3kW telecom power supply, 200kHz - 400kHz ( no load ) parallel loaded resonant converter, 42-60VDC out at 50ADC. ( no IR2110 though, gate drive emitter followers and transformers ).
  16. #16
    Full Member level 5
    May 2010
    usa
    313
    2,933
    12
    Is this reliable, or it will face problems in future?
  17. #17
    Aug 2015
    1,627
    9,987
    23
    on proteus I connected pin 3 to 4 but pin 2 doesn't give inverted signal
    sigh ... did you take pin 14 high? ...?
  18. #18
    Full Member level 5
    May 2010
    usa
    313
    2,933
    12
    it worked on proteus but it didn't work on pcb
  19. #19
    Aug 2015
    1,627
    9,987
    23
    respectfully - there may be a small fault with the implementation.
