Results 1 to 9 of 9
    Full Member level 4
    Points: 1,772, Level: 9
    Sep 2014
    india
    218
    1,772
    9
    8051 seriel data transfer
    Dear All,
    I want to transfer decimal from 0 to 999 serielly by using 89s52 seriel port for my project.but how to transfer or how to write code for decimal numbers.please reply.
    thanks,
    Tepu
    Points: 22,848, Level: 36
    barry's Avatar
    Mar 2005
    California, USA
    4,367
    22,848
    36
    Re: 8051 seriel data transfer
    What exactly do you mean “send decimal numbers”? You can send them as BCD. You can send ASCII. You cand send them as binary and convert them at the receiving end. You don’t really explain what’s going on here. Where are these decimal numbers coming from?
    •   AltAdvertisment
    Full Member level 4
    Sep 2014
    india
    218
    1,772
    9
    Actually I want to transfer decimals as BCD from one 89s52 to another 89s52 by using seriel port.please give program hint or link.
    Thanks,
    Tepu
    •   AltAdvertisment
    Points: 72,488, Level: 65
    Apr 2014
    14,736
    72,488
    65
    Please understand:
    * common serial interfaces are: UART, SPI, I2C....
    * all of them work byte-wise.
    * none of these interfaces cares about how you code the bytes
    BCD is just a coding scheme.
    It is only 4 bits wide.
    You are free to transfer one or two BCD nibbles in a byte. (as payload)
    HEX is also a 4 bits wide coding scheme, thus it makes no difference whether you transfer a HEX nibbke or a BCD nibble.
    As a simple solution to transfer the decimal value of 987:
    * code them as three BCD nibbles: "9", "8", "7"
    * add a "frame identifier" (not "0"..."9", let"s use HEX "F"
    * then you have four HEX (4 bit) nibbles: "F", "9", "8", "7"
    * pack them in two bytes: 0xF9, 0x87
    * transmit the two bytes
    •   AltAdvertisment
    Full Member level 4
    Sep 2014
    india
    218
    1,772
    9
    i wrote a simple program.which transmit character 'z'.but how to generate bytes ??
    #include
    void main()
    	SCON=0x50;
    	TMOD=0x20;
    	TH1=-3;
    	TR1=1;
    	SBUF = 'z';
    	while(TI==0);
    	TI=0;
    Apr 2014
    14,736
    72,488
    65
    Your question looks "general" on one side and "unelaborated" on the other side.
    We still have to guess: Do you want to transmit via UART?
    If so:
    I just did an internet search for "8051 UART tutorial". --> About half a million hits! Even video tutorials including code and testing. --> I think there is no need for another one.
    My recommendation:
    * go through a couple of UART tutorials
    * look for UART example code
    * modify it for your needs
    * if you encounter problems then you are welcome to ask a detailed question.. with detailed error description.
  7. #7
    Points: 253,760, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,217
    253,760
    100
    It's C programming, you can use C compiler features. I'm using printf() with hex format in this situation.
    •   AltAdvertisment
  8. #8
    barry's Avatar
    Mar 2005
    California, USA
    4,367
    22,848
    36
    Quote Originally Posted by tapu View Post
    #include
    void main()
    	SCON=0x50;
    	TMOD=0x20;
    	TH1=-3;
    	TR1=1;
    	SBUF = 'z';
    	while(TI==0);
    	TI=0;
    'z' IS a byte. It's hex 7A; ASCII 'z'.
    You can generate your bytes any way you want; WE can't tell you how to generate them. You are being REALLY unclear about what you are trying to do, or what your problem(s) are. In your above example you could just substitute a packed BCD value for your 'z'.
  9. #9
    Newbie level 1
    Points: 13, Level: 1
    Apr 2019
    13
    Yep tapu, FVM bro is correct, try using C compiler features as its C programming. :)
