Results 1 to 14 of 14
    Points: 1,141, Level: 7
    Feb 2014
    44
    1,141
    7
    Creating a very sharp pulse generator
    Hello everyone,
    I want to generate a clock with about 4 MHz frequency (should be adjustable) which is very clean and sharp.
    I can not access ready oscillators.
    I have test a crystal collpits circuit but it is not sharp enough.
    Any suggestions?
    Best Regards
    Ya Montazar
    Points: 72,488, Level: 65
    Apr 2014
    14,736
    72,488
    65
    Re: Creating a very sharp pulse generator
    Specify "sharp" in values with unit.
    •   AltAdvertisment
    Feb 2014
    44
    1,141
    7
    I meant fast slew rate. Not a specific v/us is considered.
    Apr 2014
    14,736
    72,488
    65
    Complaining about slew rate, but giving no value makes no sense.
    Points: 51,207, Level: 55
    Apr 2011
    Minneapolis, Minnesota, USA
    12,572
    51,207
    55
    A quick slew rate requires that a device change immediately from high ohm to low ohm (or vice versa), so that current flow changes immediately.
    It's the opposite of a low-pass filter. Which is like saying the highest frequency of a high-pass filter. Therefore a series capacitor is a handy way to create an abrupt spike, since it sharpens a spike into an even more abrupt spike.
    •   AltAdvertisment
    Apr 2014
    14,736
    72,488
    65
    High pass filter...
    What circuit are you thinking of?
    A simple C-R high pass filter can't increase dV/dt.
    •   AltAdvertisment
  7. #7
    Points: 253,760, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,217
    253,760
    100
    A Colpitts oscillator generates sein wave, the opposite of sharp edges. You surely need to convert the waveform, e.g. by digital logic gates with schmitt trigger function.
  8. #8
    Feb 2014
    44
    1,141
    7
    Quote Originally Posted by BradtheRad View Post
    Thanks, is there any specific known circuit for that.
    What I want exactly is to have an oscillator with specific frequency, which an equivalent could be exist in form of oscillator pack.
  9. #9
    Advanced Member level 2
    Points: 4,707, Level: 16
    Feb 2014
    634
    4,707
    16
    What's the application? If there are parts already designed for your application you'll want to use them. Don't overthink it.
    Otherwise it seems to be a problem of finding a the right driver. Fast gan fet gate drivers come to mind:
    http://www.ti.com/document-viewer/LM...28#SNOSD456328
  10. #10
    Points: 9,263, Level: 23
    d123's Avatar
    Jun 2015
    1,636
    9,263
    23
    Not sure if waveform will be neat enough with either inverter gate-based suggestion and consistent enough with the latter (RC-based), Pierce oscillator (crystal and inverter gate) or a ring oscillator made from 3 inverter gates.
  11. #11
    Points: 18,461, Level: 32
    crutschow's Avatar
    Feb 2012
    L.A. USA Zulu -8
    3,573
    18,461
    32
    What is "sharp"?
    If it's a rise and fall time of a <20ns you could drive a 5V 74HC14 Schmitt trigger inverting gate with the colpitts signal (if it's 0-5v) to square up the signal.
    Zapper
    Curmudgeon Elektroniker
  12. #12
    Apr 2011
    12,572
    51,207
    55
    Simulation showing how a series capacitor produces a spike-like waveform from a slightly rounded square wave. The series cap performs the differentiation function. (I called it a high-pass filter in post #5 because that is a more common name when used with sinewaves.)
Name:	series cap (differentiator) produces spike w advance 4MHz.png
    Out2 amplitude is greater than Out1. By mixing or merging or adding the waveforms in some manner, it can sharpen the transistions.
    Slew rate is altered further as the capacitor advances the phase (as is characteristic of capacitors). The behavior becomes obvious when Out1 versus Out2 are plotted X-Y fashion.
    •   AltAdvertisment
  13. #13
    Feb 2014
    44
    1,141
    7
    It's a good suggestion.
    Quote Originally Posted by crutschow View Post
    What is "sharp"?
    However 74hc14 is too large for me.
    I want to replace this circuit with a crystal oscillator so I do not have a large space.
    Is there any small package one?
  14. #14
    Apr 2014
    14,736
    72,488
    65
    HC1G14
