Results 1 to 4 of 4
    Advanced Member level 1
    Points: 5,265, Level: 17
    Jul 2004
    Hungary
    479
    5,265
    17
    [moved] Ds3231 RTC: temperature display (mikroC)
    On request I wrote a simple and fast function to display the temperature
    measured by the Ds3231 internal sensor.
    - no any floating operation (integer arithmetic only)
    - no any character buffer (each digit is displayed immediately after computed)
    From the Ds3231 datasheet:
    Temperature is represented as a 10-bit code with a resolution of 0.25°C
    and is accessible at location 11h and 12h. The temperature is encoded
    in two’s complement format. The upper 8 bits, the integer portion, are
    at location 11h and the lower 2 bits, the fractional portion, are in
    the upper nibble at location 12h. For example, 00011001 01b = +25.25°C
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    void Ds3231_Temp_CP(void) { // "-00.00", range: -99 to +127 degree
       // written by (©) zuisti (Istvan K)
       char msb, lsb, tmp;
       // read the two temperature registers:
       I2C1_start();
       I2C1_Wr(0xD0); // Ds3231_write address
       I2C1_Wr(0x11); // register address (temp msb, integer part), to be read first
       I2C1_Repeated_Start();
       I2C1_Wr(0xD1); // Ds3231_read address
       msb = I2C1_Rd(1); // w. ACK
       lsb = I2C1_Rd(0); // w. NACK (last read)
       I2C1_stop();
       tmp = ' ';
       if (msb.B7) { // SIGN_bit = 1: negative
          tmp = '-';
          // two's complement conversion:
          msb ^= 0xFF;
          if (!lsb)
             ++msb; // required if the fractional portion is zero
          else
             lsb.B0 = 1; // negative fract. sign, normally it is 0
       else if (msb > 99) {
          msb -= 100;
          tmp = '1';
       // the first char is a space, '-' or '1':
       Lcd_Chr_CP(tmp);
       // convert msb (binary value) to 2 ASCII digits
       for ( tmp = '0' ; msb > 9 ; ++tmp, msb -= 10 );
       // display integer portion:
       Lcd_Chr_CP(tmp);
       Lcd_Chr_CP(msb + '0'); // modulo 10 as ASCII digit
       // decimal point:
       Lcd_Chr_CP('.');
       // compute fract. part:
       msb = '0';
       tmp = '0';
       if (lsb) {
          // positive 7,6 bits: 01(25), 10(50), 11(75)
          // negative 7,6 bits: 01(75), 10(50), 11(25)
          if (!lsb.B6)
             msb = '5'; // 50
          else {
             msb = '2';
             tmp = '5';
             if (lsb.B0) // negative fract. (see above): 25 <> 75
                lsb.B7 = !lsb.B7;
             if (lsb.B7)
                msb = '7';
       } // fract. part
       Lcd_Chr_CP(msb);
       Lcd_Chr_CP(tmp);
    } // end of Ds3231_Temp_CP()
    // ******** Usage (a possible example):
     Lcd_Out(1, 1, "Temp:");
     Ds3231_Temp_CP();
     Lcd_Chr_CP(0xDF); // dec 223 = degree sign
     Lcd_Chr_CP('C');
    Points: 74,899, Level: 66
    Apr 2014
    15,182
    74,899
    66
    Re: Ds3231 RTC: temperature display (mikroC)
    No question?
    Jul 2004
    Hungary
    479
    5,265
    17
    No question?
    Yes, because my post above is a (well-functioning) solution, not a question. I just wanted to help others, so I published it.
    Kind mods, please move this to the right place (I couldn't find any better). Thank you.
    Regards:
    zuisti
    Apr 2014
    15,182
    74,899
    66
    I´ll move it to the "Hardware and PCB Design" --> "Show your DIY" section
    But are you usure it is helpful:
    * without schematic
    * without knowing about the display
    * without knowing what microcontroller
    * without knowing about compiler
    and so on...
