Results 1 to 5 of 5
    Newbie level 6
    Points: 525, Level: 4
    Oct 2016
    14
    525
    Signal Wavelength vs Transmission Line Length
    I've read that a rule of thumb is:
    T-line length >= 0.1 Signal Wavelength
    you need to consider transmission line effects. But if the T-line is "shorter", T-line effects can be ignored.
    But regardless of length, if Zo =/= Zl wouldn't issues of reflection and impedance matching still apply?
    Why can T-line effects be ignored when it is "short"?
    •   AltAdvertisment
    Full Member level 2
    Points: 876, Level: 6
    Oct 2017
    124
    876
    Re: Signal Wavelength vs Transmission Line Length
    It depends on order of mismatch. If you put 1000 Ohm 0.1λ it must be considered, because effect is very significant. For such huge mismatch effect vanishes around 0.001λ.
    •   AltAdvertisment
    Points: 72,752, Level: 65
    Apr 2014
    14,791
    72,752
    65
    As already said:
    * the effects will be there
    But the effects on signal amplitude will be less and the effects in time will be shorter. Thus it's more likely they will not harm.
    •   AltAdvertisment
    Points: 254,022, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,262
    254,022
    100
    The 1/10 lambda rules means, you can analyze transmission lines as lumped circuit (series L, shunt C) below this length without causing large errors. But the lumped elements must be still considered, their effect can be very small or large, depending on the impedance relations.
    If you are in an impedance matched design, it may be easier to use transmission line calculation methods even for short lines.
    Full Member level 1
    Points: 2,544, Level: 11
    Oct 2008
    Türkiye
    112
    2,544
    11
    A load Zl is seen different when it is looked through a tl. There is a famous formula saying zin= zo*(zload+jz0*tan(teta))...
    As you can observe, if teta is small enough(the line short enough), zin becomes zload. When the line length increases, the load start to be seen different.
