Results 1 to 3 of 3
    Full Member level 1
    Points: 1,364, Level: 8
    Nov 2014
    100
    1,364
    8
    Two scale factors in IMU
    an IMU has two parameters:
    scale factor repeatability = 1000 PPM (1-sigma)
    and
    scale factor in-run stability = 250 PPM (1-sigma)
    Question: What is the difference between them?
    Senmeis
    Advanced Member level 2
    Points: 2,915, Level: 12
    Jan 2019
    529
    2,915
    12
    Re: Two scale factors in IMU
    from https://en.wikipedia.org/wiki/Inertial_measurement_unit
    repeatability is getting the same result from doing the same thing - say you use your IMU to fly a plane from dallas to tokyo
    do this several times. the repeatability is a measure of your landing in the same spot each time
    stability is sitting still and getting the same thing - say you park your plane in denver, and leave the IMU running. stability is it saying your still in the same place
    Full Member level 1
    Nov 2014
    100
    1,364
    8
    I’m not sure if the „scale factor in-run stability“ is related to the case when the IMU stands still. Attached is an example of both parameters. It seems scale factor in-run stability is measured with the roll = 180 degrees.
    Senmeis
