Results 1 to 7 of 7
    Newbie level 3
    Points: 171, Level: 2
    Sep 2018
    171
    RF IQ Quadrature modulator
    Dear All!,
    Could anyone help to assembly a setup test. I have an IQ Quadrature Modulator (Polyphase ) with: 4 input`s (I, Ī and Q, ΞQ). Further, my RF LO(Local osc.) and RF Output (Mod. Signal). I have also, an Arbitrary Waveform Generator, which I would like to use to create my "I and Q". A RF signal Generator to my LO too.
    IF I want a signal em 2,5 GHz, which will be my setting? Could you help me? If anyone want details I will share it....as well as info about my equipment... Thank you
    Full Member level 2
    Points: 1,005, Level: 7
    Jun 2018
    Turkey
    144
    1,005
    7
    Re: RF IQ Quadrature modulator
    Maybe you can draw the setup in your mind, so we can talk about it?
    Points: 264,406, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,200
    264,406
    100
    To fully utilize the I/Q modulator capabilities, you need a dual channel arbitrary waveform generator. Adjust the amplitudes and DC offset according to the modulator specification, that's all.
    Newbie level 3
    Sep 2018
    171
    Yes, please, see the Pic. attached. Click image for larger version.
    Could you say me some more? In that case, a 10 GHz modulated signal has been wanted. Thanks,
    Newbie level 3
    Sep 2018
    171
    FvM I did it, and worked fine, the dual channel arbitrary waveform generator. Now, could say me how can I will set it signal to work as a pulsed RF signal?
    Points: 31,086, Level: 43
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,564
    31,086
    43
    A valuable and a helping document for IQ measurements
    https://www.analog.com/media/en/tech...tes/an102f.pdf
  7. #7
    Full Member level 1
    Points: 2,689, Level: 12
    Oct 2008
    Türkiye
    112
    2,689
    12
    In order to have a pulsed RF signal, either I or Q channel is sufficient. Generate a baseband pulse signal on either of them(I or Q), apply LO, you will observe pulsed RF at the output.
