+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Advanced Member level 5
    Points: 31,585, Level: 43
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    6,602
    Points
    31,585
    Level
    43
    Common mode choke SRF should selected to be at the worst case EMC problem frequency?
    The following is an app note on use of common mode chokes to improve EMC….
    https://www.schaffner.com/fileadmin/...on_chockes.pdf
    Nowhere in this app note does it mention the self resonant frequency of the common mode choke.
    Do you know why this is?
    Surely THE big thing about use of common mode chokes in EMC , is that the SRF of the common mode choke should be placed at the worst case common mode EMC problem frequency?
  2. #2
    Super Moderator
    Points: 253,898, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    44,246
    Points
    253,898
    Level
    100
    Re: Common mode choke SRF should selected to be at the worst case EMC problem frequen
    It makes little sense to specify a common mode SRF because the actual in circuit resonance frequency is set by external capacitors and/or parasitic circuit capacitances. If you don't have common mode capacitance at the device side of the choke, no common mode disturbances need to be suppressed.
    1 members found this post helpful.
    •   AltAdvertisment
  3. #3
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    6,602
    Points
    31,585
    Level
    43
    Thanks, i take it you refer to "stray" capacitance here?....but isnt there always stray capacitance?
    But surely the SRF of a common mode choke or an inductor is a major factor in the selection of inductors (CM or DM) in SMPS filters?
    At the common mode SRF, the impedance of a common mode choke peaks up very significantly, so surely you want this peak at your EMC problem frequency?
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    44,246
    Points
    253,898
    Level
    100
    If the SRF matters in your application, you have usually curves of common mode and differential impedance, as in this data sheet https://katalog.we-online.de/pbs/dat...7446630047.pdf
  5. #5
    Points: 7,761, Level: 21
    Join Date
    Aug 2015
    Posts
    1,226
    Points
    7,761
    Level
    21
    SRF is of course important in minimising the size of any EMC filter, the BW can be extended by using plastic cups on each side of the toroid to reduce C to the core and various "figure 8" winding techniques to reduce ( cancel) pickup from nearby radiators of RF noise ...
    •   AltAdvertisment
  6. #6
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    6,602
    Points
    31,585
    Level
    43
    Page 17 of AN15 (below) states that emissions from offline SMPS’s above 1MHz are usually common mode emissions….
    AN15: EMC app note:
    https://ac-dc.power.com/sites/defaul...pdf?download=1
    So then why is it that the SRF of most 250VAC rated, offtheshelf, common mode chokes, is below 1MHz?....eg, the wurth 7448640415 common mode choke has an SRF of 600kHz…
    Wurth 7448640415 common mode choke.
    https://katalog.we-online.com/pbs/da...7448640415.pdf
    Why so low?
  7. #7
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    44,246
    Points
    253,898
    Level
    100
    Why so low?
    Because common mode L is high. 10 mH || 7 pF gives 600 kHz
  8. #8
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    6,602
    Points
    31,585
    Level
    43
    Thanks, yes i agree, but then, surely it would be better to make L lower, so that SRF was higher?
    •   AltAdvertisment
  9. #9
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    44,246
    Points
    253,898
    Level
    100
    I guess not, presumed you want also common mode filter action at frequencies below SRF
  10. #10
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    6,602
    Points
    31,585
    Level
    43
    Thnaks but as the app note in the top post says, common mode emissions are usually above 1MHz.
  11. #11
    Join Date
    Aug 2015
    Posts
    1,226
    Points
    7,761
    Level
    21
    this is why 2 stage LC CM filters are common ...
