Results 1 to 6 of 6
    Full Member level 5
    Points: 2,044, Level: 10
    Jul 2015
    Faridabad India
    251
    2,044
    10
    Need help stepper motor control with DRV4832
    Hello experts,
    I need a dedicated stepper motor controller ic to drive DRV4832 bridge ic. I found L297 ic that control L298 H-Bridge ic. Can L297 control DRV4832 or other ic like L297 that fit with DRV8432?
    Points: 77,731, Level: 67
    Apr 2014
    15,755
    77,731
    67
    Re: Need help stepper motor control with DRV4832
    The DRV8432 includes just 4 halfbridges and some error detection.
    Any "controller" that is able to generate some digital signals can drive the DRV8432.
    But what function(s) do you want to implement? How do you want to drive your stepper?
    And what exact stepper motor is it?
    Full Member level 5
    Jul 2015
    Faridabad India
    251
    2,044
    10
    I want to control motor by PLC, PLC is able to generate pulse approx 10k-100khz. But limited output and we are planning to control 10 numbers of stepper motor.
    I need just a stepper driver ic that generate motor switching sequence with at list 1/32 microstepping and control switching speed with single pulse input pin. Direction control also need.
    Apr 2014
    15,755
    77,731
    67
    Not related to half bridge driver and it's function.
    What is "10k -100khz"? Is it the pulse frequency that determines the motor RPM? (Dynamic 1:10 only?). Or is it the PWM frequency to control the motor current?
    1/32 microstepping is useful information.
    But what microstepping scheme? Triangle, trapezoid, sine? Voltage (PWM) controlled or current controlled?
    I ask myself why you choose a halfbridge driver only...
    If you want control a stepper motor, why don't you choose a dedicated stepper driver that includes the microstepping feature?
    Like TB6600 or DRV8825. Just do a search, there are many others.
    Full Member level 5
    Jul 2015
    Faridabad India
    251
    2,044
    10
    Hi Klaus
    Actually i told my PLC maximum PWM speed. It will be 0 to 10khz or 0 to 100khz.
    I need sign type microstepping and PWM control.
    My motor current is 6A. I searched a complete stepper driver ic, but did not find for 6A.
    I can write some codes in a microcontroller to get my work done. But my concern was to find a cheap and easy way.
    Apr 2014
    15,755
    77,731
    67
    You still mix two different things.
    * either PWM for current control (usually fixed frequency)
    * or pulses (non PWM) for motor RPM (variable frequency)
