Array itself is the one index of an 2d array ie, strings[i][so_far[i]]
saramah
Member level 3
hI,
When I was terying to understand the tutorials from
HTML:
https://circuitdigest.com/microcontroller-projects/gsm-interfacing-with-pic16f877a
, the below 2d array is found.
if (strings[i][so_far[i]] == received)
what i understand, it is a 2-D array, and 'so_far[]' array itself is one of the another index of 'string' array. But my qestion is how this operate in the code below as mentioned in the aricle:
#define SIM900_OK 1
#define SIM900_READY 2
#define SIM900_FAIL 3
#define SIM900_RING 4
#define SIM900_NC 5
#define SIM900_UNLINK 6
inline unsigned char _SIM900_waitResponse(void)
    unsigned char so_far[6] = {0,0,0,0,0,0};
    unsigned const char lengths[6] = {2,12,5,4,6,6};
    unsigned const char* strings[6] = {"OK", "+CPIN: READY", "ERROR", "RING", "NO CARRIER", "Unlink"};
    unsigned const char responses[6] = {SIM900_OK, SIM900_READY, SIM900_FAIL, SIM900_RING, SIM900_NC, SIM900_UNLINK};
    unsigned char received;
    unsigned char response;
    char continue_loop = 1;
    while (continue_loop)
        received = _SIM900_getch();
        for (unsigned char i = 0; i < 6; i++)
                so_far[i]++;
                if (so_far[i] == lengths[i])
                    response = responses[i];
                    continue_loop = 0;
            else
                so_far[i] = 0;
    return response;
how //if (strings[so_far] == received) this line being implemented. if i had been recived "O" for "OK" at 'received' variable from calling fun //_SIM900_getch();
I REQUEST TO MAKE ME UNDERSTAND IF POSSIBLE..
TNX
The code is receiving input from the GSM modem and staying in the loop until one of the six expected responses in strings[] is detected.
so_far[] keeps track of the already matched characters in each compare string.
For the details, you should review the string processing chapter in a C programming text book.
