Results 1 to 10 of 10
    Advanced Member level 1
    Points: 2,937, Level: 12
    Mar 2015
    467
    2,937
    12
    Nichrome Wire Circuit
    Hi, all.
    i want to make a small heater. so i bought 0.1mm x 5mm nichrome strip whos resistance is 2.2ohms per 12 inch.
    The length i am using for making the heater is also 12 inch. But when i connect this nichrome wire directly to 12V 5amps SMPS, the SMPS gets shorted.
    so i connected 4.6 ohms resistor in series with nichrome strip, but still the nichrome strip does not get hot.
    Points: 2,366, Level: 11
    Created Blog entry 7 years registered
    Apr 2007
    36
    2,366
    11
    Blog Entries
    Re: Nichrome Wire Circuit
    12v / 5A = 2.4 Ohms and you are connecting 2.2 Ohms load, so you are trying to draw more current than what the supply is capable of delivering.
    The strip is rated 2.2 Ohms but at what temperature? Also did you measure the resistance to confirm the value?
    That 4.6 Ohm resistor in series is going to dissipate a lot of heat - are you sure it didn't burn out?
    Points: 260,224, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    The resistance of a Ni80Cr20 strip 0.1x5mm is 2.2 ohm/m rather than 2.2 ohm/12 inch.
    I presume you calculated wrongly. Temperature dependency of NiCr is moderate and doesn't explain the differences.
    Full Member level 6
    Points: 2,031, Level: 10
    Jan 2019
    377
    2,031
    10
    the specific heat of nichrome is 450 J/(kg K)
    you power supply is 60 W or 60 J/second
    the mass of of your nichrome wire is probably about 10 grams
    so 60 J * 1/450 kg K/J / 0.01 kg = 13 K
    so the temperature of the wire should rise about 13 degrees K
    and if we take into account the cooling of the wire in air
    (which I do not have enough information to estimate)
    the wire will not get very warm
    i'm going to ballpark the temperature rise of the wire at 10 K, or about 18 degrees Fahrenheit
    not enough to heat much of anything
    Full Member level 1
    Points: 2,148, Level: 10
    Nik_2213's Avatar
    Jul 2010
    UK
    98
    2,148
    10
    @G, would a small, low-voltage incandescent bulb, or a pair in parallel, be a better solution ?
    Socket mounted, visible Go/NoGo function, run slightly below rated voltage for extended life-time...
    Points: 39,706, Level: 48
    Mar 2008
    USA
    6,413
    39,706
    48
    You need just enough NiCr to get near, but not over,
    the power supply's current limit. You might reduce the
    voltage if it's adjustable, use a series fat rectifier(s) to
    drop just a bit of voltage (apiece), etc.
  7. #7
    Points: 52,908, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,945
    52,908
    56
    Quote Originally Posted by Nik_2213 View Post
    A dome light for automobiles, typically uses 1A at 12V. Gets hot enough so I feel it burns my fingers.
    There are 12V lamps which use a bright bulb, 20W to 60W.
  8. #8
    Full Member level 6
    Jan 2019
    377
    2,031
    10
    The OP wire does not get hot.
    The light bulb glows. Lot of heat dissipated by the filament.
    Primary difference is lack of cooling (no air surrounding filament) and a smaller resistance in the filament of the bulb.
  9. #9
    Points: 17,232, Level: 31
    Nov 2012
    3,148
    17,232
    31
    Without going into details, you can see that a soldering iron rated at 60W can get quite hot indeed (surely around 300C at ambient temp).
    With a smaller wire (straight or coiled) the temp rise can be significantly larger.
    More accurately, 10C/s, and the temp will continue to rise till the heat loss becomes equal to 60W
  10. #10
    Full Member level 6
    Jan 2019
    377
    2,031
    10
    as c_mitra and BradtheRad point out, my comment was wrong
    re-reading the thread, trastikata and FvM were likely on the right path
    2.2 ohm /m means your 12 inch wire is about 0.8 ohm. the power supply behaved as if it was shorted because it was shorted.
    try a car headlight bulb. the H7 is rated at 12V 55W
    available at most auto supply store
