[SOLVED] torque screw instead of ring terminals
manually tinned wires are a no-go for reliable and especially for high current connections.
The tin is weak and will loose contact force with time.
The best are crimped contacts - but only with a suitable, high quality crimp tool.
If you need details, do a search for "gas tight crimping".
Reactions: Zak28
    Zak28
The wires I use aren't manually tinned they are completely tined by factory, I don't tin the ends with solder.
Wouldn't soldering the ring terminal onto the wire be just as good as crimping it?
no
high quality crimp, especially gas tight crimp, is a really good mechanical contact
solder is used as glue to hold good mechanical connections in place.
solder should not be the connection
Reactions: Zak28
    Zak28
