Low Side bidirectional battery disconnect switch
Oveis.Gharan
Full Member level 4
Iran
Dear All,
I want to design a low-side bidirectional battery disconnect switch for controlling the battry connection meanwhile its charging/discharging in a BMS.
Is there anyone who could suggest me a circuitry to conroll the connection via a Microcontroller?
Thanks in advance.
BR
Oveis
Try this:
tie the gates together.
ground emitters, control to gates
the diodes are parasitic with the IGBT
you may use a solid state relay, or photoMOS, or a mechanical relay.
You know: You didn´t give any specification about voltage, current, speed....thus we can only guess.
Aren't the IGBTs Ron higher than the desired values?!
Don't you suggest the driving circuitry?
--> Please tell us your "desired values"
Since the power stage of the IGBT`s are based on a BJT structure, it is not usual refer to their Rdson parameters, but rather to their Vceon parameters.
The circuit in post #2 can also be used with power MOSFET's.
IGBT's have a specified voltage drop. Power MOSFET's have a specified resistance.
IGBT's are good for high voltage cricuits. Power MOSFET's are better for low voltage circuits.
Please give specifications/requirements for the "battery disconnect switch".
