[SOLVED] didn't find inverter for specified operating conditions
vyella1
Newbie level 6
Hi Forum,
I ran a synthesis using design compiler for a using standard cell library which has operating conditions(Voltage=1.05V, Temp=25C). Now I want to run synthesis for different operating conditions (voltage=1.05V, temp=25C). I used DC command set_operating_conditions to set the operating conditions which I want and ran the synthesis. I am getting an error "The target library doesn't contain an inverter. An inverter is required."
Hi Forum,
Maybe you dont have the libraries for the op condition you want?
