Results 1 to 5 of 5
    Advanced Member level 2
    Points: 4,140, Level: 15
    Jan 2012
    Italy
    685
    4,140
    15
    CMFB loop bandwidth requirement
    Dear friends,
    does the GBW of the CMFB loop should be equal to the differential op-amp GBW ot it has nothing to do with it.
    Thank you very much
    •   AltAdvertisment
    Points: 252,622, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,006
    252,622
    100
    Re: CMFB loop bandwidth requirement
    Application wise, you'll be looking for gain dependent closed loop bandwidth rather than gain bandwidth product.
    The answer depends. High CMFB bandwidth is desirable if a true differential amplifier is driven by an (partly) unbalanced signal and wanted to balance it, otherwise CMFB performance is not so critical. For GHz amplifiers, it's unlikely to achieve similar CMFB bandwidth.
    •   AltAdvertisment
    Jan 2012
    Italy
    685
    4,140
    15
    Thank you FvM for your reply
    Can you please tell me the reason why my vote to help is limited ?
    so I would say the GBW of the closed loop CMFB can be less than or greater or whatever value demands our application, in all cases it has nothing to affect the characteristics of the differential GBW
    •   AltAdvertisment
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,006
    252,622
    100
    Each member has a limited helpful points budget which is refilled periodically.
    Points: 338, Level: 3
    Jan 2019
    50
    338
    Your CMFB GBW does not need to be high as your differential amplifier GBW, and often its quite difficult to achieve it as your CMFB loop will see more poles than your differential amplifier. If you have large output swings, then because of the "non-linear" behavior of your transistors, the node going up and the node coming down will behave differently. A large CMFB loop GBW will try and reduce that. But its only a minor detail.
