Results 1 to 6 of 6
    Junior Member level 1
    Points: 142, Level: 1
    Feb 2019
    15
    142
    Temperature measurement on power mosfets during the power consumption in motor contro
    I am measuring case temperature placing the thermocouples on mosfets in the bridge configuration of motor control board. During the motor rotation or power consumption the six power mosfets are getting warm in my experiment and to monitor if the case temperature exceeds rated junction temperature of power mosfet's i placed thermocouples to get the data in degree centigrades. The question is how long we have to let it in running condition? How long we have to wait to check if case temp exceeds jn temp of power mosfet?
    Points: 23,285, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,460
    23,285
    37
    Re: Temperature measurement on power mosfets during the power consumption in motor co
    There are a lot of factors at play here, specifically, the physical aspects of your thermocouple, how it's bonded to the MOSFET, etc. Look at this: https://www.omega.com/techref/Thermo...ponseTime.html
    But if it were me, I'd just let it run continuously until the temperature stabilizes. Aren't you expecting it to run continuously in normal operation?
    Points: 74,693, Level: 66
    Apr 2014
    15,146
    74,693
    66
    Mosfets include a body diode. This is the same silicon as the mosfet's switch, obviously they have the same temperature.
    A silicon diode has a temperature coefficient of about 2.1mV/C in forward voltage.
    Thus a temperature rise from 25C to 150C = 125C results in about 260mV.
    If you can find a way to measure the diode's forward voltage - eg in times when the PWM switches the Mosfet OFF - you durectly measure the junction temperature. ...almost perfect without adding time delay or added thermal mass.
    This is not very easy, but If you want us to help you with this solution you should give us the half bridge schematic and the PWM timing.
    The theromcouple solution is more simple, but includes delays and can only read the case temperature instead of junction temperature.
    The thermal model from junction to case may be simplyfied as a simple RC delay.
    To get a clue about the junction temperature you need to do a multiplication (R part) and you need to take care about the rise rate of the temperature.
    This can simply made in an EXCEL chart.
    Please dont contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    Points: 16,347, Level: 30
    Nov 2012
    2,993
    16,347
    30
    If you can find a way to measure the diode's forward voltage ...
    A very elegant solution indeed.
    But perhaps you need to add /modify the circuit extensively; forward drops are best measured at constant current.
    I was about to suggest a silicon small signal diode pasted on the body instead of the thermocouple.
    Diode forward drops depend on band gap in some complex way and can give the absolute temp without the need of a reference junction.
    Measuring the temp using the built in body diode can become messy (but I am fully ignorant of the intricacies involved). But I feel that replacing the thermocouple with a simple diode may be simpler.
    Junior Member level 2
    Points: 577, Level: 5
    Oct 2016
    Volos, Greece
    24
    577
    Quote Originally Posted by vishjay View Post
    Best test this is at environmental temperature 36C for 48 hours. It will pass the test if your Heat-sink it does qualify too.
    Points: 38,970, Level: 48
    Mar 2008
    USA
    6,300
    38,970
    48
    Datalog the thermocouple readings and look for an
    asymptote. Which may change with ambient temp,
    airflow and load, but you will find one of you keep
    conditions constant.
    RTDs are maybe a better signal in noisy environments.
    Or the diode approach.
