Problem with microstrip transient simulation HFSS ANSYS
CamiloSanabria97
Newbie level 2
I need to simulate the impulse response of a microstrip in Ansys hfss so I am using the transient solution type. But i dont know how because when I create the wave port, as in frequency simulation, I get the error "The port has no terminals defined on it".
Thanks to all.
Camilo
Student and assistant Universidad de los Andes Colombia
I assigned the terminals manually, but now I get the following error: "Too few conductors were found on port 1. There should be one conductor for each terminal, with one additional reference conductor. Unintentional contact between conductors may cause this error.". I dont know why because is a simple microstrip, I only have two conductors (Ground plane and the cooper of the line)
When setting up the terminals, did you select the ground plane to be the reference? There should only be one terminal per port.
If this is set up properly, then you may have unintentional contact somewhere else, e.g., with an unassigned boundary which may default to a PEC.
