vhdl - config with adv7511
avishai11910
Newbie level 2
Hello everyone I am a beginner electronic engineer, and i need to write a vhdl model for confifig with device ADV7511 in vhdl, i use with a code:
i use with table 23 and with RGB 10 bit style 1 in adv7511 datasheet , can anyone help me with what values i need to send to the register in adv7511 ?
this what i undestand from the datasheet:
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
x"4110",
x"9803", -- must be like this
x"9AE0", -- must be like this
x"9C30", -- must be like this
x"9D61", -- must be like this
x"A2A4", -- must be like this
x"A3A4", -- must be like this
x"E0D0", -- must be like this
x"5512", -- need to be else for rgb or ycbcr
x"F900", -- must be like this
x"1505", -- RGB 444
x"4838", -- RGB 00 ?? -- x"4838",know is lsb to msb, else x"4818" msb to lsb,
x"161A", -- RGB 444 10 bit style 1, 1st half on rising edge - YCrCb clipping ??
x"1710", -- output aspect ratio 16:9, external DE
x"D03C", -- auto sync data - must be set for DDR modes.
x"AF04", -- DVI mode
x"4c05", -- Deep colour off (HDMI only?) - not needed
x"4000",
the 2 bit in the left tell the adress, and the 2 bit in the right tell the data in Hexadecimal.
i on that two weeks and I can not understand. please help me.
thank you.
[Moderator action: email address deleted]
1) if you’re a beginning engineer, why are you mucking around with a very complex interface (HDMI)?
2) I didn’t see any Table 23 in the data sheet; the last table was 22.
3) There is nothing ANYWHERE in your post about VHDL. In fact, there is nothing in your post that looks anything like a question.
Please, ask a question.
1) Hi, i need to do this for a project.
2) in the datasheet of adv7511 PROGRAMMING GUIDE page 35,
hi, someone can take a look and see if i initialize register like i need in table 23 ? or i did something wrong with the value i send to the register?
thank you.
