Results 1 to 2 of 2
    Newbie level 1
    Points: 15, Level: 1
    Mar 2019
    15
    APC BK 650EI bip bip
    Hi, once the led lighted with red color and after followed the instructions I provided Exchange the battery with a new original APC one. The result ?
    It sounds irregularly with a noise intermittent bip. I put a digital tester to reveal the voltage, it is right, more or less V. 12,80 to 13. 10. I already simulated the outage and it supplied the devices connected normally.
    Is important to know the same tests are executed with one more APC original battery and the effects are been equals to the previouses.
    The question is: why it sounds ?
    I don't have the cable to connect it to a PC, probably is matter to tune the voltage level before it sounds.
    Does anyone an answer ? Thanks
    •   AltAdvertisment
    Member level 3
    Points: 283, Level: 3
    Jan 2019
    64
    283
    Re: APC BK 650EI bip bip
    Did you use the correct battery?
    Did you put the new battery in correctly?
    Did you give the new battery time to charge up?
    You do not need a USB cable to a computer for it to work correctly.
    User's Manual:
    https://www.apc.com/salestools/ASTE-...7VBG_R1_EN.pdf
    It should not rqu
