Page 2 of 2 FirstFirst 1 2
Results 21 to 38 of 38
  1. #21
    Advanced Member level 1
    Points: 4,641, Level: 16
    Jul 2005
    Oakland
    449
    4,641
    16
    Re: need 7pF to 10pF at 2.5GHz
    thank you very much for your kind guidance, Dr Volker. I Hope we can hire you as a consultant in the future. have a great day ahead.
    i have another question. can we do design LTCC implementation in ADS?
    •   AltAdvertisment
  2. #22
    Points: 12,460, Level: 26
    Apr 2014
    1,930
    12,460
    26
    Quote Originally Posted by pragash View Post
    Sure. We used Sonnet EM and Empire 3D EM, but basically any layout tool plus EM solver is possible.
  3. #23
    Jul 2005
    Oakland
    449
    4,641
    16
    mistake.. pls ignore
    dr volker,
    i have one last question. im getting different inductance when i simulate using a different set of formulas. Please let me know which one is correct and why?
    results and formulas are attached side by side. the 1st formula is from ADS template.
    ADS template have two method. extracting ind from Y11 and also Y12! both giving totally different results. Y11 shows -ve inductance whearas Y12 shows positive! which one to believe!
  4. #24
    Apr 2014
    1,930
    12,460
    26
    There is no "correct" or "wrong" equations, they are valid under certain conditions, as mentioned in the ADS template.
    Assume you have an inductor represented by a pi model, with series RL and shunt C to ground. You can then extract the pure L from the series path (excluding shunt effects) or the effective series inductance (including the effect from shunt components), or the effective input inductance into one terminal when the other terminal is shorted. You then get 3 different curves. All are valid, just different what you consider "the inductance". So you need to decide what value is relevant for your design use.
  5. #25
    Jul 2005
    Oakland
    449
    4,641
    16
    this inductor connected in series and not shunt to ground. Pure inductance and resistance extraction (Y12) shows +ve ind which is correct. shunt to ground inductance (Y11) shows negative inductance which is not my case.
    this is a differential measurement of the inductor using reactance (imag(Z)). its only valid for differential configuration which is also not applicable for me. the best is two port measurement.
  6. #26
    Apr 2014
    1,930
    12,460
    26
    But your inductor has parasitics: capacitance to ground.
    That is possibly correct due to parasitics. Can you upload the inductor *.s2p, so that we extract the equivalent circuit model?
    I agree that you should use the full S2P data in circuit simulation. I just tried to explain why there is more than one correct answer regarding "the inductance value".
  7. #27
    Points: 252,660, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,006
    252,660
    100
    I think the problem is not considering the prerequisites of ADS distributed components. MSIND is a microstrip inductor, it's referring to a MSUB microstrip substrate definition creating a respective shunt capacitance. Reading the ccdist manual thoroughly should clarify everything.
    Place a lumped inductor, e.g. AIRIND1 model and both setups should give equal inductance.
    •   AltAdvertisment
  8. #28
    Jul 2005
    Oakland
    449
    4,641
    16
    could you please clarify what is ccdist manual?
    •   AltAdvertisment
  9. #29
    Apr 2014
    1,930
    12,460
    26
    Can you upload the inductor *.s2p so that we have a useful data basis for discussion?
  10. #30
    Jul 2005
    Oakland
    449
    4,641
    16
    Dr.Click image for larger version.
    actually, I don't know how to generate an s-parameter file from the ADS. due to that, i sending you my coil parameters. you can simulate it and get the S-parameters. sorry for the inconvenience caused.
  11. #31
    Apr 2014
    1,930
    12,460
    26
    In the ADS data display menu: Tools > Data File Tool
    This can create SnP from simulation dataset
  12. #32
    Jul 2005
    Oakland
    449
    4,641
    16
    thank you so much Dr. Volker. i have created s2p file. please refer below.
    coil.rar
  13. #33
    Apr 2014
    1,930
    12,460
    26
    Data starts at 2.3GHz, which is not enough to extract a model. Please provide wideband data that goes down to DC.
  14. #34
    Jul 2005
    Oakland
    449
    4,641
    16
    attached the s2p as requested. thanks.
    coil_2.rar
  15. #35
    Apr 2014
    1,930
    12,460
    26
    Indeed, your inductor has enough shunt capacitance to ground to become capacitive in some port configurations. Here is a simple pi model, extracted from your S2P:
    .subckt SON3_38 1 2 REF
    C_C1 1 REF 0.109335pf
    C_C2 2 REF 0.105086pf
    L_L1 1 3 63.69988nh
    R_RL1 3 2 1.0e-5
    .ends SON3_38
    If we evaluate Y11 (port 1 input impedance with port 2 shorted to ground) it looks capacitive at high frequency because we then have 63.7nH || 109fF.
    If we use the differential port configuration, we have a higher SRF because then 63.7nH || (109fF in series with 109fF)
  16. #36
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,006
    252,660
    100
    ccdist = "Circuit Components Distributed Components" ADS manual
    •   AltAdvertisment
  17. #37
    Jul 2005
    Oakland
    449
    4,641
    16
    Quote Originally Posted by volker@muehlhaus View Post
    L_L1 1 3 63.69988nh
    R_RL1 3 2 1.0e-5
    .ends SON3_38
    Dr Volker, how did u extract the exact C associated with the coil?
  18. #38
    Apr 2014
    1,930
    12,460
    26
    I went the easy way and used the Sonnet PI model extraction.
    You should be able to get a similar answer in ADS by extracting the shunt path elements. For your convenience, I have posted some code from my Inductor Toolkit model extraction.
    Y = stoy(S)
    omega = indep(S) * 2 * pi
    Cshunt_port1= 1 /(-omega*imag(1/(Y(2,1)+Y(1,1))))
    Cshunt_port2= 1 /(-omega*imag(1/(Y(2,1)+Y(2,2))))
