Results 1 to 11 of 11
    Full Member level 5
    Points: 2,739, Level: 12
    May 2010
    usa
    276
    2,739
    12
    microcontroller interface with led and relay
    I lost the atmega (PORTD.0 is burnt and always low), . led on PD0 is connected to 500 ohm and PORTD.0 is gone. but the othe port PD1 isn't affected its led is connected to 220 ohm. what is wrong with this connection
    Points: 77,368, Level: 67
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,663
    77,368
    67
    Re: microcontroller interface with led and relay
    It would be better to connect the LEDs and series resistors across the relay coil but assuming you also have the grounds connected to the MCU, it should still work without causing damage.
    •   AltAdvertisment
    Points: 70,762, Level: 64
    Apr 2014
    14,472
    70,762
    64
    With this circuit you can't kill the port.
    --> Show us your real circuit.
    We can't verify
    * your power supply circuit including capacitors,
    * your reset circuit...
    Points: 28,642, Level: 41
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,527
    28,642
    41
    Blog Entries
    How did you came accross this conclusion? Have been PD0 working so far and suddenly did not show activity anymore? Where is the code used on this experiment, are you sure you have configured I/Os correctly?
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Full Member level 5
    May 2010
    usa
    276
    2,739
    12
    Yes it was working for a month then stopped suddenly. I thought that the resistor value is low and the port pin couldn't handle it so i increased the resisor and changed the atmega then i lost it again. This is the third time to post it why this pin? Why not the other pins. Nothing is connected to it but led and transistor
    We can't verify
    You want the pcb layout?
    •   AltAdvertisment
    Apr 2014
    14,472
    70,762
    64
    It depends whether you want it to be checked by us or not..
    And the sane is true with all the informations you give.
    Until now we can only check the schematic and the given part values.
    And we decided, that the schematic will not caused the described problem.... thus
    There is a chance that:
    * the error doesn't exist at all --> show/tell how you verified it
    * the PCB layout is problematic --> show us your PCB layout, if you want it to be checked
    * wrong wiring --> photo
    * wrong capacitor types --> exact type and manufacturer, datasheet
    * unstable power supply --> scope pictures
    * soldering errors --> detailed photo
    * the used part values don't match the schematic values --> photo
    * wrong port setup --> code
    and so on ... temperature (ambient, soldering), ESD, EMC, ...
  7. #7
    Full Member level 5
    May 2010
    usa
    276
    2,739
    12
    this is my circuit except that the serien is connected directly through resistor to the MU
  8. #8
    Apr 2014
    14,472
    70,762
    64
    you try to fool us?
    Now the "killed" PORTD.0 has a totally different circuit..
    And additionally you tell us that the circuit for the "killed" port is even different than in the new schematic.
  9. #9
    Full Member level 5
    May 2010
    usa
    276
    2,739
    12
    Sorry i forget to tell you its counterpart on my circuit. Pin 14 is the burnt pin.
    I thought that it won't make difference
    I didn't expect that you would ask me for my real circuit so i give portd as atypical example
    •   AltAdvertisment
  10. #10
    Apr 2014
    14,472
    70,762
    64
    So is OK when we give equally confusing, unreliable and "typical" answers?
    Now it is Pin14.... this is PB0.
    * On one schematic totally unconnected, ...
    * at the other schematic named as "motor" but no other circuitry, no other information...it has nothing to do with LEDs and relays...
    Iīll spend my time with other things..
  11. #11
    Full Member level 5
    May 2010
    usa
    276
    2,739
    12
    I attached the relay board. I found the problem it was the transistor 2n2222 that is connected to PD4. what are the possible causes for losing this transistor?
